SM Wheels For WR400 From Donor Bike
3 replies to this topic
  • chambers
Posted May 14, 2008 - 11:23 PM
I am looking for a set of SM wheels for the WR400, I have chance to get a set of wheels from a CRF 450 but am unsure if they will fit. From what I can tell the 2002 WR (Mine) has a 20mm front and 22mm rear where as the CRF has 20mm front and 22mm rear. Is there any wayt of making them fit, what would I need? :thumbsup:
  • tweav
Posted May 14, 2008 - 11:29 PM
It really depends on the hubs . alot of the sm wheels have a universal hub , that you just swap bearings and spacers to make them right for a different bike . some even have an interchangable sprocket mount.
  • chambers
Posted May 14, 2008 - 11:49 PM
From what I can gather the wheels I have been offered are specific for the CRF as opposed to universal. I would have thought spacers can be used to offset them correctly but Im not sure how to solve the spindle size issue
  • tweav
Posted May 15, 2008 - 01:18 AM
most likely you could order bearings to fix the axle sizes . you would have to measure everthing to be sure the axle will fit thru the bore of both hub , then check the o.d of the bearings themselves . then order new ones with same o.d .and thinkness and with a i.d. that fits your axle.
