o ring change interval
13 replies to this topic
  • mx614
Posted May 13, 2008 - 05:30 PM
OK did the o ring AP mod with DR.D full system on my 07 YZ450, my question is how long do the #78 o rings usually last before needing replaced? As in run hours :thumbsup:
  • Family Man
Posted May 13, 2008 - 08:30 PM
I was told they should last a couple of years, if installed correctly. P.S. at my local Ace Hardware the oring is a number 58.
  • William1
Posted May 14, 2008 - 02:28 AM
Should last a long time. Easy to replace on the bike it it does fail, a one minute job.
  • Kasjok
Posted May 14, 2008 - 02:34 AM
How do you do it in one minute?
  • William1
Posted May 14, 2008 - 06:00 AM
1) Remove the cover over the throttle wheel
2) Using long smooth tipped needle nose pliers, remove the old O-Ring (if one was previously installed)
3) Install the new O-Ring, using the same pliers
4) Install the cover
Took me almost as long to type that as the change takes.
  • Kasjok
Posted May 14, 2008 - 06:31 AM
When I did mine I had to tear down the subframe and shock to get near the throttle wheel cover. Seemed too tricky to get it done from above exhaust joint :thumbsup:
Posted May 14, 2008 - 06:38 AM
I'm curious as to whether you have tried this on your aluminum framed WR, or a late YZ450, or not.
  • William1
Posted May 14, 2008 - 07:46 AM
Yup, I did the install the first time this way. Used a ball end allen to get the cover off. May help in that I have small hands.
  • mx614
Posted May 14, 2008 - 02:04 PM
Thanks I was just wandering for maint check purposes after someone said theirs kept breaking. It didnt look as if it had much strain on it to me.
  • MaxPower
Posted May 14, 2008 - 02:59 PM
[COLOR="Green"]I think I used a 78[/COLOR]
  • Berm-Saw
Posted May 15, 2008 - 09:29 AM
who all here did te O ring mod, what differences did you notice, i might be intrested in doing it on my bike
  • William1
Posted May 15, 2008 - 10:53 AM
You can get a box of ten for 2 bucks. Charge five friends $2 each to oring their carbs, and get a free lunch and have spares left over.
It makes a difference, even on my 08 that supposedly has a stiffer spring from Yamaha.
  • Kasjok
Posted May 15, 2008 - 11:02 AM
William1, did you back out the AP squirt adjuster screw as much as you could or did you left it like it was?
  • William1
Posted May 15, 2008 - 12:53 PM
The timing screw is the last part you tweak. You turn it to get the squirt to just miss the slide. Screwing in makes the squirt sooner, out, later. Leak jet controls volume and sensitivity of the squirt.
  • Hot  28 replies
  • Hot  30 replies
  • Hot  47 replies
  • Hot  113 replies
