120/90/18 or 130/90/18 Dual Sport Tire Size
9 replies to this topic
  • Stoy66
Posted May 13, 2008 - 01:31 PM
I've decided to go with the Dunlop D606's. Stock size is 110/90/18. I know the 120/90/18 will fit but how about the 130? Anyone with experience with this?
  • MaxPower
Posted May 13, 2008 - 05:44 PM
[COLOR="Green"]Tire weight makes a noticeable difference
I installed the rear wheel from my 125 on the 450 cause it had a knobby and my 18 inch wheel had a dual sport tire on it.
The 125 rim had an aluminum sprocket, one rim lock and of course a smaller tire with a standard tube.
I was blown away how much better the bike handled even with a knobby that was too small for the big 450
So in opinion I feel you should go with the smaller tire
[/COLOR]
  • taycam
Posted May 17, 2008 - 06:36 PM
I have a 130/90 Pirreli mt21 and it fits with no problem
  • swede426
Posted May 17, 2008 - 06:42 PM
Wow I did'nt know you could fit a 130 wheel in the swingarm, whats the clearance between tire and swingarm?
  • taycam
Posted May 18, 2008 - 06:30 PM
there is between 1/2" and 5/8", lots of room. The tire sits on the rim well just a little bit of a pain to mount:crazy:
  • sjperry
Posted June 03, 2008 - 05:17 PM
i just put 130/90-18 on my L and when i got it i thought this tire will not fit,it will and makes the bike seem bigger on road had to trim the chain gaurd a little out side lugs just rubed it stock.
  • chrispy1202
Posted June 12, 2008 - 01:28 AM
I have a 130/90/18 Michelin on my bike right now(for dirt only). To get it to fit all you need to do is slide the brake caliper off the end of its rail to allow the knobbies past the tight spot and then slide it back into place. I use the D606 tires in a 120/90/18 size and they are great. The 130 Michelin fit, so i would say the D606 should as well.
  • DB_Cooper
Posted June 12, 2008 - 03:42 PM
Ive run both 110-120 combo as well as the 120-130 combo on my WR450.
Ive stayed with the smaller combo for a couple reasons. 1. Less unsprung weight makes the bike handle/feel better. 2. Unlike a bigger torque motor [XR650r] the smaller tire can be "spun up" easier for cornering.
  • justbackitin
Posted June 12, 2008 - 07:25 PM
Yea you can fit a 160/60R17 in there!
:thumbsup:
  • swede426
Posted June 12, 2008 - 11:29 PM
:thumbsup:
He he, obviously!
