08yz450 Hiccup???
2 replies to this topic
  • dirtbikeaddikt
Posted May 10, 2008 - 06:25 PM
I'm runnin mostly stock but with a boyeson quikshot. 155 Main, 45 Pilot, 4th Clip needle, Fuel Screw 1 1/4 turns. So here's the problem....Right around quarter throttle there seems to be a hiccup where the bike cuts out. If I punch the throttle hard while riding in a low gear, it misses and then goes. Any suggestions?
  • Ga426owner
Posted May 11, 2008 - 07:44 AM
Did you adj the squirt duration for the accel pump with the quickshot gauge tool?
It may need re adj
  • todds924
Posted May 11, 2008 - 07:40 PM
Are you running the stock pipe? If so, what elevation are you at? According to what your running, you have changed the main from a 160 to a 155 and raised the needle one posistion from stock? I would ditch the quickshot personally. I've tried the standard quickshot and the quickshot2 on my 06 and 08. It worked better stock. I will assume you are above 3000 ft. that is why you dropped to a 155 main, what i don't understand is richening up the needle????????
  • 10 replies
  • Hot  113 replies
  • 5 replies
