bogs over whoops?
5 replies to this topic
  • Mike Martel
Posted May 06, 2008 - 07:16 AM
I just put a new piston and rings in my 06 yz450f. On the first test ride I went to a new riding area in the woods. this place was very tight and dangerous; never shifted out of 1st or second. The bike ran fine but got a little hot of course. I crashed while crossing a big log in the trail. the bike would not start for about 10 minutes. I had to turn the gas off and hold it wide open to get it to fire. Once going again the bike ran fine as long as i didn't hit any whoops. Every time i hit a bump bigger than a foot high the bike would bog out and then return to normal operation once over the bump. I did notice my gas tank seemed to be bulging out my radiotor shrouds on each side of the bike. Gas was also coming out of the gas tank cap before the vent house. I rode to the truck and went home. I fired the bike up the next day and it started second kick. Any idea what the problem was here?
  • Pezman04wrx
Posted May 06, 2008 - 07:19 AM
Bad gas cap vent? ...
  • Mike Martel
Posted May 06, 2008 - 07:21 AM
that is what i was thinking but after all the work i did on the bike i was not sure. I took the bike apart 6 times before i could get it to start. one of the shims slipped off the lifter messing up the valve clearance on 2 intake valves. Once i got that figured out it cranked write up. I will try and replace the hose.
  • Slinkyman16
Posted May 06, 2008 - 08:30 AM
did you put in a hi-comp piston? if so you may need to change the jetting, or it could be that you have a bad tank vent...
Posted May 06, 2008 - 10:40 AM
Sounds like float level to me. Check to see if it's too low.
  • William1
Posted May 06, 2008 - 11:14 AM
+2 on the float level.
  • 0 replies
  • 10 replies
  • 3 replies
  • Hot  50 replies
