plastic question
6 replies to this topic
  • whoops dude
Posted May 05, 2008 - 10:08 AM
Will the front number plate and rear fender from a 08 yz450f fit on a 05 wr?
  • SJMC_DON
Posted May 05, 2008 - 10:14 AM
The rear fender will definitely not work, (unless someone else can prove otherwise)... you'll need an 03' - 05' YZ rear fender but should bolt right up after trimming for coolant resevoir mounts.
The number plate is fairly universal to the YZ's but I cannot say for sure that an 08' YZ # plate will work on the 05' wr... at a minimum you will have to fabricate some kind of bracket or get creative with some long (12"+) zip tyes.. (this is what I have always done)... the upper tripple clamp on your WR does not have the tab in which you bolt the top of the # plate too :eek:
  • whoops dude
Posted May 05, 2008 - 10:16 AM
ok thx for the feedback
  • JSanfilippo
Posted May 05, 2008 - 12:51 PM
I believe 123bigcoopdawg576 made an '06 YZ rear fender work for his '06 WR
  • Charles De Mar
Posted May 05, 2008 - 01:16 PM
'05 yz fender fits 05 and 06 wr!
  • justbackitin
Posted May 05, 2008 - 06:20 PM
I tried a number plat on my 06. The computer forces the plate to be mounted way forward so it looks sot of gay. I stuck to the stock headlight because it looks better. Does the 05 wr even have the computer?
  • JSanfilippo
Posted May 05, 2008 - 07:27 PM
No. Just a 4 digit mechanical tripmeter
