Clutch Lever Adjustment Help
2 replies to this topic
  • yamahaxt
Posted May 05, 2008 - 05:15 AM
Had to change my clutch lever do to a small crash. The problem I have know is that the clutch is to touchy for my likings. The new lever was not an exact match to the stock one (The pin hole was a little bit farther in). I have to let the lever almost completely all the way out for it to engage (I perfer it to start to engage when I start to let it out). I tried to adjust it but nothing changed so I figure I am missing a step. Also not sure which is the proper way to turn the cable adjuster for what I need. Did a search but could not find anything. Any advise on fixing this or a forum that has this topic?
  • face_plant
Posted May 05, 2008 - 10:24 AM
which lever you are using may not be the right clutch pull distance
proper adjustment is 3-5mm at the top
it does help to know what bike you have the newer ones have a black round knob you spin to adjust
  • yamahaxt
Posted May 05, 2008 - 10:49 AM
Sorry, its a 2006 WR450.
