Header Overflow Pipe.
5 replies to this topic
  • Richard56
Posted May 10, 2002 - 03:51 AM
Can we seal the overflow pipe shut??? Oil usually drips from there that is why I'm thinking of sealing it shut?? Will there be any harmful effects or damage to the engine??
  • z4me
Posted May 10, 2002 - 04:12 AM
No.
Is this a question?
Yes. It is there to equalize pressure in the crankcase. Some people have routed it up behind the number plate and placed an air filter on it to keep it from dripping and sucking up water under certain conditions.
  • YAMAKAZE
Posted May 10, 2002 - 06:41 AM
Only if you want to blow out the Rubber Gromets on the side of the head..... I saw one do 15ft once...That was Kind of Cool....
Bonzai :)
  • Richard56
Posted May 10, 2002 - 10:42 PM
Hmm... sound kinda cool to blow up the rubbers. (Joking)
So can we route it behind the radiator then? You know, just beside/near the cap where oyu put your motor oil?
If routed to a higher point, will the oil still drips?
  • Guy
Posted May 11, 2002 - 12:33 AM
:) There is a HUGE thread somewhere, imaginatively titled....."crankcase breather" covering all sorts of discussions regarding this little piece of rubber! :D
People have expressed all sorts of concerns re the routing of them and the best ways of dealing with it :D
  • MX_Tuner
Posted May 11, 2002 - 03:54 PM
One common reason for excessive oil coming from teh breather hose is overfilling your oil level. It should be at the top of the serrated area on teh dipstick when the motor is scorching hot, not right after you change the oil. Oil expands. If it is full when you change it, it'll be overfull when at operating temp.
