Steering head bearings
2 replies to this topic
  • DW295
Posted May 02, 2008 - 09:53 AM
I know that bearings and races are normally a matched set, but is it as important for steering head bearings to be a matched set? I am changing the triple clamps on my bike and I have new stock bearings with the new clamps. I was wondering if I need to change the races to make the swap or if I could just leave the races and swap the clamps.
  • 642MX
Posted May 02, 2008 - 10:01 AM
As long as your races look good, then just swap the clamps and be done with it. If they look pitted or rusty, then change them out.
  • Ga426owner
Posted May 02, 2008 - 12:43 PM
You can choose not to replace the races but, they are so easy to install why wouldn't you. I am anal and have to use new stuff with new stuff.....Remember any wear on the existing races will cause the new bearing to wear faster. I suggest replacing them as a matched set. The hard part is getting the bearing installed on the steering stem. Do you need help removing/installing the races? http://www.thumperta...ad.php?t=531298 :eek:
  • Hot  113 replies
  • Hot  47 replies
  • On January 15, 2017
1998 yz400f will not idle. by trolley
  • Hot  32 replies
