YZ450 front rim on a WR450
3 replies to this topic
  • Doc200
Posted May 01, 2008 - 11:53 AM
Anyone know a simple way to make a 2007 YZ450 front rim (no speedo drive) fit a 2007 WR450 (speedo drive)? Thanks.
  • 123BigcoopDawg576
Posted May 01, 2008 - 12:07 PM
you cant make the speedo work with a yz wheel...you can make the wheel work just fine with out the speedo and the yz spacers
  • Doc200
Posted May 01, 2008 - 12:20 PM
Thanks Dawg. I should have mentioned that I don't need the speedo to work on the WR. I'm trying to set up a set of rims for the ice and the hot set up seems to be a 19" rear with a stock front.
  • Frostbite
Posted May 01, 2008 - 12:26 PM
I believe the only difference is the spacer on the speedo side. I think the WR spacer will work on the other side. I put an older YZ wheel on my 07WR, and just had to change the speedo side.
