DRZ250 crossover parts
66 replies to this topic
  • mini_S_man
Posted 28 April 2008 - 07:29 PM
HI,
  I have been doind lots of research for aftermarket parts and replacement parts (as I'm sure alot of you have)
Anyway I was thinking we should try to make this thread a list of all the crossover or interchangable parts  that you can use from other bikes. I'd assume the most popular parts would be shared with the DRZ400E/S DR650SE and the older DR250/350.
I'LL ADD EVERYONE'S SUGGESTIONS TO THIS TOP POST WHEN THEY COME IN
I'll start the list:
1 I've been found foot pegs are the same as DR650SE. So that means you can buy any aftermarket pegs, like Pivot pegs that are listed for the DR650SE.
2 Oil filters are the same as DRZ400
3 Rear Sprockets same as DRZ400
4 Rear wheel DRZ400 (needs250 spacers tho)
  • Tim Taylor
Posted 29 April 2008 - 04:17 AM
I am pretty sure that the rear wheel is the same as a 400.  They use the same sprockets
  • wolffo1
Posted 29 April 2008 - 07:24 AM
the rear sprocket is def the same
I have a 52 tooth renthal on my 2001 Dr-Z250
  • DustyMcNuggets
Posted 29 April 2008 - 06:36 PM
yeah i can attest to this. My DRZ 400 has my DRZ 250 rim on it and the 250 has the 400's. I had a trackmaster on the 250 and wnated to put it on the 400 after i bought that. Easy swap -spacers are slightly different size though.
  • mini_S_man
Posted 29 April 2008 - 09:47 PM
Nice stuff fellas.
keep it coming
  • DustyMcNuggets
Posted 30 April 2008 - 04:56 AM
anybody thought of bolt on parts from the LTZ 250 quad? I would think that mufflers, carb upgrades, those sorts of things might be compatible.
  • mini_S_man
Posted 30 April 2008 - 05:59 PM
FWIK the suzuki 250 quads use a completely different engine. Just chacked pats diagrams of an 04 ltz250 and they are 2 valve head and different bore x stroke.
Good thinking tho
  • DustyMcNuggets
Posted 01 May 2008 - 04:18 PM
wow -you would think that Suzuki would have wanted to reuse the engine in as many products as possible. How bout the DR 250 and 350's?
  • Olalla7700
Posted 01 May 2008 - 04:30 PM
The frame looks similar to those used on the RMZ from the 90s... what about that possibility?
-Kerry
  • Manofaltes
Posted 01 May 2008 - 05:29 PM
I think the DR250 and DR350 might have some possibilities by looking at photos, but I have never seen them in person.
  • mini_S_man
-Kerry
Yeah I was thinking that. I've been looking through all the parts diagrams for a suzuki with similar rear frame so that i could buy an MX style rear guard. the closest I have seen is the 1990's rm250/125.
I'm going to look at a wreckers to see if they have an older RM i can copare it to in person.
  • Olalla7700
Posted 01 May 2008 - 08:14 PM
  I meant RM... been thinking 4 strokes and motocross lately...  Yeah, I've been looking to drop the lights and possibly go to a different tank (with shrouds) to give it a different, more MX, look.  Investigating to see if parts will cross over from an RM of the 90's on paper, for now.
-Kerry
  • wolffo1
Posted 07 May 2008 - 04:57 AM
talking about the DR250/350...
I was wondering if the after market gas tanks available for those would work fit a DR-Z250.
www.justgastanks.com has them for the DR line
  • mini_S_man
Posted 11 May 2008 - 02:20 PM
For some reason TT wont let me edit my first post today. But i thought i better add a PERFORMANCE mod that i have just completed.
Replace carb with thew Mikuni TM33P. This carb was stock on the "performance" model DR350 apparently, but you can source one NEW for under $300. You do need to swap a few bits from your old carb for the throttle pull. but not that hard.
  • thewrx
Posted 17 May 2008 - 09:21 AM
Doesn't Kawasaki and Suzuki share the same platform for some of the dirt bikes? I thought the drz is the same as the klx, not sure.
  • mini_S_man
Posted 18 May 2008 - 04:50 AM
Unfortunatly not the 250. kawasaki and suzuki 'share' the 400 and the 110 I think.
  • jsvits
Posted 21 May 2008 - 04:07 PM
Does anybody know if a different shift lever is possible on the DRZ 250?  Will one off a 400 give you some more room to get a larger foot under? I find shifting my 250 to be challenging with a larger foot.  Does anybody else have this problem?
  • wolffo1
Posted 22 May 2008 - 12:11 PM
I tried moving my shift lever up one notch to make more room, but then I couldn't get into the upper gears
  • wolffo1
Posted 29 May 2008 - 06:18 AM
the more I look at the DR250/350 the more I think the aftermarket gas tanks would fit...see pics
http://denver.craigs.../699251905.html
acerbis makes a 4.25gal model for the DR350
Clark makes a 4.2gal for both the Dr250 and DR350
IMS makes a 3+gal for the Dr250/DR350 also
  • Manofaltes
Posted 29 May 2008 - 08:38 PM
I agree the tanks look very much the same in photos, but I have not seen the two bikes side by side in person.
