Fresh 426 motor not starting easy
No replies to this topic
  • jfreadman
Posted April 28, 2008 - 02:20 PM
The bike engine has finally been rebuilt. I’m finally back to riding, and need some advice with its setup. Before I ignorantly ignored my cam chain stretching the bike was running great. The throttle response was strong from the bottom to the top with no hesitation. I credited the response to the power now, installed to get back some of the bottom end grunt lost with the YZ 450 EX cam.
:p
I made the assumption that if I left my carburetor alone and simply put it back on a fresh motor. The beast would be back. She has the dreaded hesitation off of the bottom and doesn’t want to start. Bumping the pilot up and installing the O ring mod cleaned up some of the hesitation, but was awful to start unless I turn up the idle high.
:eek:
What can I do for the starting problem? “Will start with a slightly cracked throttle”
O ring mod in conjunction with the BK mod? “recently installed the O ring mod”
I have RedBeard450’s AP Mod How to Guide and this doesn’t look like a fully applicable mod to my 426.
Will the carb need a little tweaking once the motor breaks in.
02 WR426
160 MAIN
200 MAIN AIR
Skinny YZ needle “I would have to pull for number”
CLIP # 2
48 PILOT
75 PILOT AIR
2 TURNS OUT
Grey cut / Yz throttle stop / Uncorked / O RING MOD / BK MOD / POWER NOW / HOT CAM EX (for the decompression ) sea level to 1000’
