2008 AIS removal
4 replies to this topic
  • wartsnuff
Posted April 25, 2008 - 01:06 PM
Hey Guys,
I know this has been posted to death. but i have not seen it for a 2008 model year. not sure whats changes were made if any from the 2007 model year
fist i removed the seat and all the plastics,
Then with small pair of pliers i pulled the tube fitting off
Then removed the 2 x8mm bolts holding the AIS unit in place
Pull the clamp off the tube and feed the air box tube out.
Put sealant and plug in the block off plug
Finshed! well almost still have to put the plastics back on
The AIS unit complete
and the project complete
I do have one question, the rear plug was not friction fit at all... it just would slip in without any effort :thumbsup: does that seem right
also note i didnt have to remove the rad or even unbolt there is plenty of room without getting close to damaging the rad!
anyhow, sorry for posting this procedure again
cheers
Warts
  • Dube2
Posted April 25, 2008 - 02:39 PM
what about the carb mods? it took me all day because I removed the sub-frame. I didn't remove the tube/hoses as california is getting pretty wierd on the green sticker bikes. So you can't tell on my bike as I just plugged the hoses up. :ride:
same for 07 from what i hear...........:thumbsup:
  • wartsnuff
Posted April 25, 2008 - 06:17 PM
well i live in Winnipeg Manitoba Canada,
the bike will never be in california :thumbsup:
so no worries to me.
cheers
Warts
  • JSanfilippo
Posted April 25, 2008 - 06:37 PM
Did you plug that fitting from the airbox? If not, your bike is going to suck in dirty air from there. (the fitting is behind the airfilter, therefore the AIS draws clean filtered air instead of dirty airbox air)
I just re-read and saw the rear plug was slip fit. Either put some silicone on it or plug it using a vaccum plug w/ hose clamp
  • wartsnuff
Posted April 27, 2008 - 06:58 AM
yea no pics of me pluging it. the kit came with a plug.. i siliconed it as well just to be sure.
but thanks for heads up just in case i didn't :thumbsup:
cheers
Warts
