running rough when hot???
1 reply to this topic
  • danny-goddard
Posted April 24, 2008 - 02:38 PM
hi there my wr 426 runs mint when i first crack it up but as soon as the engine starts to warm if i rev it the engine takes a while to settle back down?? also when im riding if i give it the beans it misfires a little?? the mods are- throtle stop screw cut down,lid taken off air box, extra holes in air box,yzf header pipe with race end can, standed jetting.:thumbsup: any help will be great cheers danny
  • William1
Posted April 24, 2008 - 03:48 PM
Hanging idle typically means you need to open the fuel screw more or possibly need a larger pilot or have a vauum leak.
For the other issue, does it run better when cold than get worse as it heats up? If so, the needle is a bit rich, try moving the clip closer to the flat. If it is the opposite, move the clip the other direction.
