'07 450 timing chain replacement
13 replies to this topic
  • chan470
Posted April 23, 2008 - 03:57 PM
I'm replacing timing chain on bike. When I opened up engine I realized I was on tooth off on the exhaust cam. I had only 13 pins between timing marks. What damage could have been done by being one tooth off? The bike ran great. I reshimmed in July of last yr so I imagined that is when I mis-timed bike. The valve clearances where still in spec.
I have replaced timing chain does this look right?
I know gray has cover this alot but I just want to be sure. Thanks alot! :thumbsup:
  • chan470
Posted April 23, 2008 - 04:38 PM
I'm an idiot!! I just realized correct timing for a 450 is 13 pins. :thumbsup:
Posted April 23, 2008 - 07:36 PM
Once again DO NOT COUNT PINS between cams unless you are timing a 450 cam into a 426 head.
Use the timing marks as shown in the book. And, yes, the correct distance between cams on a 450 is 13 pins, but that is not how they are timed.
  • 02WR426Cali
Posted April 23, 2008 - 09:21 PM
In that picture it looks like 14 pins to me? Am I counting wrong?
  • Kasjok
Posted April 23, 2008 - 09:48 PM
I counted also 14 and the exhaust cam seems to be a tooth wrong.
  • tnl
Posted April 23, 2008 - 09:55 PM
Note the above statement!
Posted April 23, 2008 - 10:41 PM
The pin count can be used as a backup double-check, but remember that each cam must be timed to the CRANK, and not to each other.
  • chan470
Posted April 24, 2008 - 05:01 AM
yes it is 14 but I moved it from 13. And your correct it is the exhaust cam. Sorry for all the confusion.
Posted April 24, 2008 - 05:44 AM
That's OK, I was never confused. :thumbsup:
  • Wiz636
Posted April 24, 2008 - 11:36 AM
I laugh every time I see somebody ask the 'pin count' question because I know this is coming from Gray. :thumbsup:
  • Wiz636
Posted April 24, 2008 - 11:39 AM
By the way, to further confuse the issue I'm pretty sure that the illustration drawing in the manual incorrectly shows 14 pins between the marks. :thumbsup:
  • chan470
Posted April 24, 2008 - 12:28 PM
That is exactly how this error began. I was dissembling cams and counted 13 pins @ tdc then looked it up in manual illustration was 14. I freaked out, was going to sell the bike because I had around 6 races since I re-shimmed. I'm glad it was right. :thumbsup:
Posted April 24, 2008 - 02:56 PM
True, but for the literate among us, the text of the manual does not instruct you to count the chain pins, nor note what the count should be.
  • todds924
Posted April 24, 2008 - 06:39 PM
This picture is WRONG!
