clutch thrust washer/spacer
4 replies to this topic
  • andy250
Posted April 23, 2008 - 12:00 PM
I put a new a new Hinson clutch basket and pressure plate in my bike last night. When reassembling, the thrust washer doesn't seat on the splined portion of the shaft - It's sitting on the smooth part against the clutch basket. Is this right/OK? A quick search shows it's normal
(http://www.thumperta...t=thrust washer)
but I just though I'd ask again for piece of mind....
Why is this spacer splined if it isn't supposed to mate with the splined portion of the shaft?
Posted April 23, 2008 - 01:34 PM
Pull the main shaft toward you and see what happens.
  • andy250
Posted April 23, 2008 - 01:43 PM
I can't - it's already buttoned up. Won't this just effectively slide the washer further down the narrow, non splined, portion of the shaft? I think what you're getting at is that the splined portion is fully seated within the boss and won't interfere with the thrust washer. Yes?
The clutch seems to work well. Is this really OK?
Posted April 23, 2008 - 01:49 PM
OK, I was thinking of something different. In this case, the non-splined section of the shaft just behind the splines where the washer runs is smaller than the OD of the splined section. To have the washer able to slide over this and still center up on the smaller diameter prt of the shaft, the washer was splined to match the shaft so the ID of the washer's splines would center it. It looks weird when you assemble it, but that's how it goes.
  • andy250
Posted April 23, 2008 - 01:56 PM
Outstanding! Thanks for the help.
  • Hot  28 replies
  • 9 replies
