2006 yz450f Reliability Any Problems?
15 replies to this topic
  • dejavudarrell
Posted April 21, 2008 - 09:28 PM
Looking at buying a used 2006 yz450 any feed back on reliability ? I'm selling my 2000 yz426 never had a problem.
  • FriscoKLR
Posted April 21, 2008 - 10:06 PM
Its a great bike and big step forward from your old bike. Make sure you re-grease the rear linkage from time to time with regular maintenance it should be good to go for a long time.
  • cowboyona426
Posted April 22, 2008 - 07:25 AM
No issues with mine, but it's got low hours on it. Also keep an eye on the steering head bearings, especially if you power wash your bike. The seal on the top of the steering head under the clamp has been known to leak- I think the 07 one is a better design.
  • Ga426owner
Posted April 22, 2008 - 07:50 AM
Some of the 06s have had a stretched Cam Chain. This can jump and cause havoc, but a easy fix -
The headbearing seal design is pityful...bearings must be maintained every 6hrs to keep from rusting you can upgrade seal to 07 -08
Mechanically they are bullet proof and the motor is pure magic!
  • x2468
Posted April 22, 2008 - 08:00 AM
good little bits of info here. keep em commin. (I too want to get an 06 yz450)
  • Justin89
Posted April 22, 2008 - 08:43 AM
The Engine is just pure awesome...IMO its the best engine of the 06, 07, and 08. The suspension comes stock is pretty sweet too. Very reliable and built solid!
Posted April 22, 2008 - 09:26 AM
Here are the only "weak" points I can think of right off hand:
> Fork seals. The '06 went to a low drag design to slick up the suspension further, and ended up with seals that leak early. The replacements have been upgraded so they shouldn't repeat this if you use current stock.
> Steering head upper bearing seal. Like Dave said, it leaks. The replacement upper bearing currently listed incorporates a second seal integral with the bearing and fixes this. The upper seal itself remains the same, however.
> Shift cam index lever ("stopper lever"). The '06 again went to a redesign here, using a small bearing in place of the typical simple roller to improve shifting. A very few of these bearings have fallen apart. No major damage has resulted from this as far as I know, but it's a good idea to use a magnetic crankcase drain plug, so that if it does let go, the 8-10 pinhead sized ball bearings will end up there. Again, the '07 part was improved.
> Water pump seals. Actually calling this a weak point is maybe too critical. But, I have heard a larger number of complaints of leaking water pumps on '06's than older bikes. Not a lot, but some. My oldest '06 just had one go out after 22 months, and that's the first one I've ever had fail. Still a pretty small thing.
  • dejavudarrell
Posted April 22, 2008 - 06:58 PM
Thanks for the feed back, Next question can I go faster because it handles so much better than my old 426?
  • cowboyona426
Posted April 22, 2008 - 07:43 PM
darrell- even if you're not going faster, the 06 feels faster because its so much lighter. I rode my 00 426 for 6 years before I traded it for my wife's snowmobile and bought my 06... I loved my 426 to death but the 06 is just better, hands down. Feels meatier too (more power).
Posted April 22, 2008 - 08:19 PM
The '06 has more power than the 426, so it should feel like it.
The biggest difference to me is that I can ride the '06 much harder much longer than I could the '03 without getting so beat up I have to be helped off the bike.
  • Ga426owner
Posted April 23, 2008 - 04:30 AM
Amen brother.....the 03 is a beast.....
  • Beaz
Posted April 23, 2008 - 01:13 PM
Thats funny i have a 01 426 and have been thinking the same thing
  • mulisha00
Posted April 23, 2008 - 07:02 PM
I just recently did what you are considering with the help of the board and the search button. I had a 02 426 that had a good amount of hours on the bike and still was powerful and very reliable but I needed something newer. I got a 06 450 and couldn't be happier. The bike power wise is more linear and smooth than the 426. It feels a little more tame powerwise but the 450 is actually just a smoother delivery of power. The weight of the two will baffle you while riding them. You will not notice weight all that much unless you go back and ride the 426.
I'm thrilled to death with mine.
I did have the water pump seal and fork seals leaking on mine but an hour of time and a few seals and everything is perfect. You cannot go wrong. Do it.:thumbsup:
  • Rantzow 100
Posted April 23, 2008 - 07:50 PM
I race the crap out of mine and considered a new one (08) however the motor is the best one made to date. All the magazines put it down for too much power, but the throttle works both ways and I've never had a problem being up front to the first turn!
  • vh5150
Posted April 27, 2008 - 01:05 PM
best bike I have ever had. I love it, just wish it would cut to the inside of turns a little better. That is my only complaint, but it is probably mine own lack of skill!!
  • djtroy
Posted April 28, 2008 - 01:11 PM
No its the bike not you.
