valve clearance for 2005 crf450
8 replies to this topic
  • craigfedd
Posted April 21, 2008 - 04:56 PM
Can anyone find the clearance for the valves on the crf 450 2005.
Thanks
Craig
  • cjxrider125
Posted April 21, 2008 - 06:00 PM
int: .006 +- .001 in (.16+-.03 mm)
ex: .011 +- .001 in (.28+- .03 mm)
  • honda123
Posted April 26, 2008 - 04:53 PM
^^^^ exactlty
  • HappyG
Posted April 26, 2008 - 06:19 PM
as per faq;
Valve Settings
Seems like there is some opinion here, but it looks like running the closer than the book will extend the valve face by setting the valves into the pockets a tad easier.
.004" on the intakes
.008 on the exhausts
Now the decompressor can do a couple different things here. If you were to run the decompressor at .014 in addition to the .008, youre net is only .022 instead of the recomended .024. You can add the missing .002 to the secondary measurment or simply run it slightly tighter overall. The result will be opening the decompressor just slighty earlier than normal which will reduce the kicking effort just slightly. Guys with High compression pistons may find the bike is less finicky to start.
  • rhino roof
Posted April 26, 2008 - 06:48 PM
I also run .004 intake/.008 exhaust alittle tigh is better.
  • honda123
Posted May 01, 2008 - 10:07 AM
just curious why do u say tighter is better on the valves.. i know loose isn't better..
  • HappyG
Posted May 01, 2008 - 11:33 AM
once again a search finds info per rhc
this is for you tech heads . Valve seating velocity this is the speed that your intake valve is impacting the seat .in genral you will see velocity in the 25 inches per second to 35"per sec range these are for maximum rpms . here is an example this is a very similar cam that im using to the stock crf cam.with your valve lash set @.006 " and your bike reving to 10500 rpm your seating velocity is 26.9 inches per sec. @.009"lash the same rpm your seating velocies are 32.49 inches per sec. and @11200 where your crf hits its rev limiter', with .009"lash your velocity is 34.657 inches per sec.this is genral rule of thumb 25"for a endurance engine that will have to make along race 30" for say a sprint car engine requireing lots of maintenance and 35"for a drag car that you hope runs for 7 secounds.the point im trying to make here is when installing new valves in your crf try setting them on the tight side of the spec it will lower your seating velocity and make your valves last longer . also when your engine is hot they gain lash raising the velocity. i supose that an engine running very hot and being set up cold on the loose side could exibit valve problems.Ron
  • crf-f crf-r trx cbr
Posted May 01, 2008 - 01:11 PM
just checked mine on my 07 crf450r supermotard and @46.3hr.s the valves are right @ .004in and .008 exhaust right where i set them after the 5 hour romp-athon when new......good stuff!!!
  • BJJ450r
Posted March 24, 2012 - 04:47 PM
How should the Feeler gauge feel when slid into place? I was told that spec for a 2005 crf 450r should be at .005! The gauge for that clearance was snug,but the .004 fit smoother with a little drag!! Any ideas?
New woods machine by agreb12
  • Hot  24 replies
Honda CRF450R 2017 by Chris.GVS
Honda CRF450R 2017
  • 0 reviews
2017 crf450 Dyno tuning by moto867
Dirt Bike   Make / Model Specific   Honda   CRF450R/RX
  • Hot  39 replies
Jetting help for my popping backfiring nightmare by Budstang
  • Hot  57 replies
what kind of gas do you guys run by Funnyguy
  • Hot  62 replies
