What is a good replacement battery for my 06 WR450
3 replies to this topic
  • MountainMax
Posted April 18, 2008 - 05:38 PM
My battery wont' hold a charge anymore, What is a good replacement one other then stock?
  • farkawi
Posted April 19, 2008 - 05:40 AM
The stock Yuasa is the best battery you can get for the WR. Unfortunately battery prices have gone thru the roof this year. Even the "cheap" brands are expensive now.
  • SID013
Posted April 22, 2008 - 11:42 PM
You could shave some weight off the top & get a lightweight unit from Ballards in Oz.
http://www.ballards..../CATALOGUE-2008
Cheers
  • ETP
Posted April 23, 2008 - 10:11 AM
Couple of thoughts:
The stock battery should last longer than a couple of years. At 4 years my stock battery is getting a little weak, but still holds a charge.
Maybe you should check the charging system on the bike to make sure its outputting well over 13 vdc at the battery, while running..
Also, if you had the stock battery on a continuous charger, and not a "smart" charger, maybe that shortened its life.
