plastic front sprocket cover
5 replies to this topic
  • _JoNeS_
Posted April 17, 2008 - 03:06 PM
Is it possible to remove the front plastic bit of the case saver but leave the actual case saver bit on, I'm guessing you just use shorter bolts so it holds the case saver tight against case ?, Im trying to source some shorter ones with a socket head as the original philips screw type head on mine have rounded (previous owner must of had issues with things being tight). If not ive got some DRC replacements with socket heads but they are same length as originals so I will still have to run the plastic cover. Just wondering if any of you fellas have done this ?
  • thorracing271
Posted April 17, 2008 - 03:18 PM
Yes it is. Thats what most people do. They usually give the metal case saver a run under a wire wheel to give it a nice shine. As for switching out the bolts, good idea going with the socket head. A lot more reliable and take longer to round off
  • _JoNeS_
Posted April 17, 2008 - 03:23 PM
So they just put shorter bolts in then dude ? to hold it in place, as I'm guessing it would rattle about with the original bolts in there as there too long, its kinda hard to describe, not been able to work on my bike for a few weeks now due to some pretty bad injuries !
  • 2012 450 xc-w
Posted April 17, 2008 - 03:56 PM
IMHO, the aluminum will not protect your case in a catastrophic failure. I run TM Design for case saver. Well worth the $.
  • todds924
Posted April 17, 2008 - 04:30 PM
Yes you can run it like that, just use shorter bolts
  • _JoNeS_
Posted April 18, 2008 - 12:27 AM
:thumbsup: thanks mate
