  • Instagram
Related Reviews
PCC Motor 19"/16" Front/Rear Honda CRF150R MX Wheels Set Black Rim Red Hub 07-15
Last review by MotoX88294
Yamaha YZ250F 2017
No reviews available
Be the first to review this
Yamaha YZ450F 2016
Last review by YZJeffro64
Yamaha YZ250 2014
Last review by MSEG77
Yamaha YZ250F 2016
Last review by 16Yamama
Related Garage
Yamaha YZ250F (2016)
Owner: 16Yamama
Added on Yesterday, 06:59 PM
* * * * * 3 votes
Wheel Interchange: What fits what?
Yamaha YZ450F Yamaha YZ250F Yamaha YZ426F Yamaha YZ400F Yamaha YZ250 Yamaha WR450F Yamaha WR250F Yamaha WR426F Yamaha WR250 Tires & Wheels Wheels
144 replies to this topic
  • Monk
Posted September 24, 2015 - 11:22 AM
will my wheels and exhaust from my yz450f 2014 fit the 2016 model? Thanks in advance
Yes
  • Monk
Posted September 24, 2015 - 11:24 AM
What rear hub will fit a 2014 yz450f ? Will the previous models? Will a 2010 yz250f rear hub fit ?
Rear hub
2009 YZ450F-current
2010 YZ250F-current
  • kx06
Posted September 24, 2015 - 11:38 AM
Rear hub
2009 YZ450F-current
2010 YZ250F-current
So a 2010 yz250f rear hub will fit a 2014 yz450f ?
  • Monk
Posted September 24, 2015 - 11:48 AM
Yes
  • EarthCruzn
Posted September 25, 2015 - 01:53 PM
This Yamaha 5ET-25311-00-00 HUB, REAR is used on these models and components:
  • EarthCruzn
Posted September 25, 2015 - 01:59 PM
This Yamaha 17D-25311-00-00 HUB, REAR is used on these models and components:
  • patrick2wd
Posted October 21, 2015 - 10:37 PM
I have a set of YZ 2011 wheels which should fit my new 2016 WR.
Only need to change bearings and it should be a straight fit!!
  • atomic410
Posted November 16, 2015 - 11:22 AM
I lost track in the past posts, so sorry if this has been answered already.  I have rear hub/wheel 5ET-25311-00-00 what do I need to do to make it fit a 2011 yz450f?  I also have front wheel 5NY-25111-00-00 and it looks to me like that is a straight bolt on.?  Thank you
Posted November 16, 2015 - 11:46 AM
At this point, I don't know that anyone has yet found bearings that will increase the axle size of the 5ET hub to the 25mm size used on the '09 and up (17D...00).  There have been a few goofy ideas offered and one or two that actually make some sense, but none look like really good solutions.
  • atomic410
Posted November 16, 2015 - 12:09 PM
could I just run the axle and blocks from a bike from one of those years?
Posted November 16, 2015 - 01:26 PM
...And wheel spacers.  BUT, the swing arm would not be supporting the axle as designed.  The blocks themselves would, and they weren't meant to do that.
  • LeBonPat
Posted December 06, 2015 - 11:52 AM
I would like to remove the speedo of a 2015 250 WRF. Would a YZ spacer + seal fit ?
Thanks
Posted December 07, 2015 - 07:48 AM
No.  The speedo drive side of the WR hub is different.
  • Jackiiii
Posted March 06, 2016 - 03:12 PM
Hi everybody I want to ask a question
I wont to change my Yamaha WR450F (09) rear wheel with 19 inch Im looking in ebay wheel from YZ250 (02) 2stroke,but i not sure its the same to fit and if you know wich year YZ/F rear wheel can I use for WR450F (09)
Thanks in Advance
  • brad12345
Posted March 06, 2016 - 05:30 PM
Thanks
flatland racing have what you need
  • chrismtb
Posted March 18, 2016 - 12:23 PM
I'm looking to get a rear wheel for my 2001 WR250F and have found a 2002 YZ250F wheel.  Am I understanding correctly that it should work?  It would be 19" vs 18", but that doesn't seem like an issue.  Would I need different spacers?  Would the brake rotor be the same?
  • GuyGraham
Posted April 07, 2016 - 10:08 AM
Yes, the hub is the same
  • JayHD
Posted August 15, 2016 - 08:55 AM
I bought a pair of wr426 wheels but don't have the odometer drive for it nor do I want it as I am using the wr off road I bought Yz 426 wheel bearings and spacers but I know the odometer side bearing hasn't got a cover without the odometer there acting as it... Will it work without and will the bearings for the hub ?
  • onefatroach
Posted October 22, 2016 - 11:41 AM
So much to read in here. I tried to find the answer to my question but I had no luck.
Recently found some excel wheels for an 05 WR450 and I'm wondering if they will fit my 2015 WR 250F ?
  • SmallTownReject
Posted October 26, 2016 - 05:01 PM
Hello. Newbie here. Wondering if a set of moto9 wheels off a 2014 kawasaki450 will fit onto my 2005 wr450f. Thanks.
How much will I battle engine temps? by 69fastback
Dirt Bike   Make / Model Specific   Yamaha   WR/YZ 250F
  • Hot  28 replies
2002 yz250 Revive with WR Transmission Guide (pic heavy) by blbiker56
  • Hot  36 replies
  • Hot  30 replies
First Harescramble by 2000YZ250
  • Hot  36 replies
  • 5 replies
