  • Instagram
Related Reviews
Yamaha YZ250 2014
Last review by MSEG77
Yamaha WR250F 2016
No reviews available
Be the first to review this
Last review by Tommyk_55
PCC Motor 21"/19" WHEELS SET for Honda CRF250 CRF450 CRF 250 450 FRONT/REAR RMH08
Last review by MotoX88294
Yamaha YZ250F 2017
Related Garage
Yamaha WR450F (2007)
Owner: IrideWR
Added on January 20, 2017
* * * * * 3 votes
Wheel Interchange: What fits what?
Yamaha YZ450F Yamaha YZ250F Yamaha YZ426F Yamaha YZ400F Yamaha YZ250 Yamaha WR450F Yamaha WR250F Yamaha WR426F Yamaha WR250 Tires & Wheels Wheels
144 replies to this topic
  • Scooter426
Posted May 05, 2015 - 01:16 PM
cool thx
  • Baldwin
Posted May 05, 2015 - 03:13 PM
Anyone know what axle blocks are compatible from year to year?
I have a 2002 YZ426 and I believe the axle blocks differ from the 2000-2001 YZ426 due to the updated swingarm. Anyone know if my 2002 takes the same axle blocks as 2003+ 450s?
  • Jimmy.Nichols
Posted May 06, 2015 - 11:48 PM
So will a 99 yz 125 rear fit a 00 cr 125 ?
  • Baldwin
Posted May 07, 2015 - 04:14 AM
I checked the parts fiche and the 2002 YZ426 has the same axle block part numbers as the 2003 & 2004 YZ450F / YZ250 2 Stroke.   2005+ Look to have changed, but I believe they are still the same size - Probably a minor change to the axle block that required the new part number.
  • V-MAN
Posted May 20, 2015 - 09:40 PM
I have been looking for an extra set of wheels for my 2013 WR450F.  The bike is plated and has DOT tires on it almost always.  The tires I am running are not ideal for some of the riding I have been doing.  I wanted to have the extra set of wheels with pure knobbies and sproket more suited for off road and just swap around.  I found a set of wheels for a 2010-13 YZ250F ... will these wheels work for me?
Thanks,
Don
Posted May 21, 2015 - 05:53 AM
Front yes, rear no.
  • V-MAN
Posted May 22, 2015 - 04:06 AM
Front yes, rear no.
Thanks grayracer, contacted the seller and he won't split the set so I'll keep looking!
Posted May 22, 2015 - 06:13 AM
The rear wheel would in fact fit the bike, but it's a 19" rim, which might be just fine in and of itself, but the rim is also a narrower width than should be used with 100-120 width tires.  (1.85" vs. 2.15").
The front would also not run your speedo.
  • V-MAN
Posted May 22, 2015 - 07:53 AM
grayracer -
According to his ad the wheels are 18/21?  Here is a copy of his ad posted:
"Complete set of DNA wheels that will fit '10-13 Yamaha YZ250F. May fit other years if you change the spacers.
Good bearings, seals, like new OEM front rotor, ok rear rotor. Sprocket with 2 rides on it and pretty decent tires still. IRC M5b on rear and Dunlop MX32 on front.
18 in rear
21 in front"
I could live without the speedo because I had to add a trail tech to get plated (non re-setable odometer).  I figured I could add a spacer if needed on front?
Posted May 22, 2015 - 08:26 AM
DNA hubs will be more widely adaptable because they're set up to accept alternate spacer kits so as to cross fit to more bikes.  They would likely work.
  • jimdager
Posted June 03, 2015 - 05:54 PM
Awesome info, I think I have my answer, but just a bit of clarification.  I have a 2008 wr450f that I am converting to SM.  I purchased a used set of excel hoops laced to stock hubs, from a yz450f.  the person I bought them from had got them used, so he does not know the specific year the hubs came off of, but he had them mounted on a 2008 yz450f without problems using stock spacers, etc.  what, if anything will I need to mount them to the wr?  I believe rear will mount up fine, but a little unsure on the front?  can I just use my stock spacers, and unhook the speedo cable?  plan on running trail tech anyways, so not an issue, or do I need to get yz spacers, bearing seals, etc?  thanks for the help, looking to order parts asap if needed, as wheels should be here in a couple of days.  thanks in advance
Posted June 05, 2015 - 06:38 AM
The rear will fit, but you will need to remove the speedo drive from the axle and use the short right side spacer/seal collar from a YZ to fit the front.
  • D-volts
Posted June 28, 2015 - 04:29 PM
I have a 95 yz250 and need to update the rims, dose anyone have an answer?
  • Wanny14c
Posted July 31, 2015 - 09:59 AM
Will wheels from a 2000 426 fit on my 98 yz400f? I read the post about what fits what but was a little confused.
Posted July 31, 2015 - 01:10 PM
Front yes, rear, no.
  • EarthCruzn
Posted July 31, 2015 - 01:42 PM
                          CHAIN PULLER BLOCKS   FITS 02-04 YZ250 YZ125 YZ250F WR250F, 02 WR426F YZ426F, 03-04 YZ450F WR450F - 5NY-25388-00-00 5NY-25389-00-00
  • Goonyz400f
Posted September 04, 2015 - 12:27 AM
Would 04 wr450 front and back wheels fit a 99 yz400f
  • EarthCruzn
Posted September 05, 2015 - 07:41 AM
1999 YZ400F-
FRONT AXLE- FITS 99-04 YZ125 YZ250, 98-00 YZ400F WR400F, 00-02 YZ426F, 01-04 YZ250F WR250F, 03-04 YZ450F WR450F – 5BE-25181-00-00
FRONT HUB- 140 R-Y - AXLE OD 20MM - BRG TO BRG 68MM - ROTOR OD 245MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 96-00 YZ125 YZ250, 98-99 YZ400F, 00-01 YZ426F - 4SS-25111-00-00
REAR AXLE- 22MM FITS 99-04 YZ125 YZ250, 01-04 YZ250F WR250F, 99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 99-00 WR400F, 01-02 WR426F - 5ET-25381-00-00
REAR HUB- 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-13 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-08 YZ250F WR250F 03-08 YZ450F, 99-00 WR400F, 01-02 WR426F, 03-08 WR450F – 5ET-25311-00-00
  • fmv60691
Posted September 07, 2015 - 10:34 AM
will my wheels and exhaust from my yz450f 2014 fit the 2016 model? Thanks in advance
  • kx06
Posted September 24, 2015 - 11:10 AM
What rear hub will fit a 2014 yz450f ? Will the previous models? Will a 2010 yz250f rear hub fit ?
1997 wr250z cylinder interchangeable 1997-1998 yz250 by westernaustralia
  • 9 replies
2005 YZ250F Throttle Position Sensor, Please Help me? by Yamaha_2005_YZ250F
Dirt Bike   Make / Model Specific   Yamaha   WR/YZ 250F
  • 7 replies
  • Hot  38 replies
2002 yz250 Revive with WR Transmission Guide (pic heavy) by blbiker56
  • Hot  36 replies
How much will I battle engine temps? by 69fastback
  • Hot  28 replies
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
