  • Instagram
Related Garage
Yamaha YZ250 (2005)
Owner: themotoviking
Added on December 07, 2016
Related Reviews
Yamaha WR450F 2015
Last review by Ken S
Yamaha WR250F 2016
No reviews available
Be the first to review this
Yamaha WR450F 2017
Yamaha YZ450F 2016
Last review by Goof331
PCC Motor 21"/19" WHEELS SET for Honda CRF250 CRF450 CRF 250 450 FRONT/REAR RMH08
Last review by MotoX88294
* * * * * 3 votes
Wheel Interchange: What fits what?
Yamaha YZ450F Yamaha YZ250F Yamaha YZ426F Yamaha YZ400F Yamaha YZ250 Yamaha WR450F Yamaha WR250F Yamaha WR426F Yamaha WR250 Tires & Wheels Wheels
  • Please sign in to reply
141 replies to this topic
  • Monk
Posted February 22, 2015 - 11:11 AM
Yes i mean the rear,Thanks. I thought about machining the hub to make for the bearing fit to match my 22mm shaft.
Make sleeves...
  • velocity1
Posted February 22, 2015 - 12:19 PM
Make sleeves...
Thought about that to,Thanks I just found some new wheels that i won’t have to change bearings, Maybe trim some bushings is all,thats no big deal
Posted February 22, 2015 - 08:10 PM
Sleeving the bearing ID in order to fit the late wheels on the early axles creates a sleeve only 1.5 mm thick (.059").  Strikes me that the way to approach the problem is to press steel sleeves into the bearing pockets and bore them to fit the 22 mm bearings.  Anyone look at that yet?
  • Monk
Posted February 22, 2015 - 08:27 PM
Downside being it wouldn't be easy to go back to the 25mm bearing without some work. The sleeves work quite well and are quickly reversible..
Posted February 23, 2015 - 07:00 AM
The inserts could be made to fit the hubs any way one might want, and there's no reason they couldn't be removed.  Depending on how exactly the late model wheel was to be used, it could be a lot cleaner conversion, and less subject to damage in service.
  • gishta21
Posted March 06, 2015 - 04:10 PM
Greyracer because you are a walking encyclopaedia with wheels I'm looking at 2013 Wr450 to fit an 2002 yz250 From what I understand it won't fit without mods but how hard are the mods? Fitter by trade so can machine up stuff just want it to be reliable cheers
Edited by gishta21, March 06, 2015 - 04:10 PM.
Posted March 07, 2015 - 10:18 AM
The rear hub and bearings are the same one on both bikes, so it should be just a matter of using the spacers that came with the bike the wheel goes onto.
On the front, the first thing you'll need to check is the axle diameter.  The hub is the same going back to earlier WR's, which had the same axle size as the older YZ, but the '13 lists different bearings, and I haven't paid enough attention to the WR to know if the axle size changed.  If it did, just use bearings for the '02.   But the problem that needs modification is that the WR hub is cut out for a speedo drive that becomes the right side wheel spacer and dust shield.  A custom spacer has to be turned out on a lathe that serves those two purposes.
  • gishta21
Posted March 07, 2015 - 03:32 PM
Sweet thanks, it's actually a yz250wr that I want to motard so I'll need the speedo prongs off the wr hub, thanks for your help appreciate it
  • racerx217
Posted March 25, 2015 - 08:45 PM
any way to make a hub from a 08 yz450 fit a 12 yz450 with different wheel bearings?
  • Monk
Posted March 26, 2015 - 05:55 AM
Rear hub? No...
Posted March 26, 2015 - 06:26 AM
Not so far, no.  '09 and onward fit.
  • racerx217
Posted March 26, 2015 - 09:03 AM
Rear hub? No...
Yes i figured that was the answer but wanted to double check. Found a killer deal on a kite/dirt start wheel i wanted but it wont fit...... oh well.
  • GHILL28
Posted April 01, 2015 - 10:10 AM
Will any of the newer WR250/WR450 REAR wheels fit up with a 2014+ YZ450F (or '09+ YZ450F I should say, they got the larger axle at that point from what I'm reading).  Looking for an 18" rear at some point.
Posted April 01, 2015 - 11:09 AM
No.  The WR still uses the old 5ET...00 hub, same as the '08 and earlier YZ.  The old/new YZ wheels use a different spoke set, as well, so the spoke flange diameters are probably different.
  • GHILL28
Posted April 01, 2015 - 11:25 AM
Check. Thanks.
  • weitzc
Posted April 11, 2015 - 09:13 AM
Will an 09 yz450f rear wheel fit a 2014 yz450f?
  • Monk
Posted April 11, 2015 - 09:47 AM
Yes
  • ahaussman123
Posted April 22, 2015 - 02:25 PM
OK, question.
I have a 2005 WR450f I just recently acquired. It came with a  2nd set of rims that have street tires on them, and the hub on the street front rim does not work with my spacers. It appears to be the older 98-01 edition, with the four braces around it. After searching everywhere, going to every motorcycle shop in the Rochester area, it seems my best bet is to attach oil seals to each side of the bearing and fabricate outer spacers.
I'm assuming this because the speedo gear is just too small for this hub, there is extra space when the caliper and disc is attached, and I don't need it anyway I am using a trail tech....  I do have access to the machine shop.
The way I planned to go about this was attach the wheel to the caliper, then measure the distance across from hub to fork on both sides, and cut to size proper cylindrical spacers, saving the speedo gear and OEM dust cap spacer for the dirt wheels. Will this work properly? Would I get sudden locking of the brakes going highway speeds, because that is really not something that I want....
  • Scooter426
Posted May 05, 2015 - 08:40 AM
Hi Folks.  I have 2 sets of wheels for a 2010 YZ450f and am planning to buy a new 2014 or 2015 YZ250F.  Will the wheels fit and what do I need to do to make them fit.  I know the rear is 2.15 wide on the 450 and 1.85 wide on the 250F.
thx
  • Monk
Posted May 05, 2015 - 08:49 AM
thx
The rear with fit, the front will not. The front has a 20mm axel where as you will need a 22mm axles size. No bearings I have found have that different inner/outer bearing size to make work with those hubs...
  • 0 reviews
  • Hot  47 replies
Yamaha WR250F 2017 by Chris.GVS
Yamaha WR250F 2017
  • 0 reviews
Is this normal by AJ_BRO
  • Hot  37 replies
Yamaha YZ250 2017 by Chris.GVS
Yamaha YZ250 2017
  • 0 reviews
