  • Instagram
Related Garage
Yamaha YZ400F (1999)
Owner: Thumpacular
Added on January 18, 2017
Related Reviews
Yamaha WR250F 2015
Last review by Jason Enger
Yamaha YZ450F 2016
Last review by YZJeffro64
Yamaha WR450F 2015
Last review by Ken S
Yamaha YZ250F 2017
No reviews available
Be the first to review this
Yamaha WR250F 2016
* * * * * 3 votes
Wheel Interchange: What fits what?
Yamaha YZ450F Yamaha YZ250F Yamaha YZ426F Yamaha YZ400F Yamaha YZ250 Yamaha WR450F Yamaha WR250F Yamaha WR426F Yamaha WR250 Tires & Wheels Wheels
144 replies to this topic
  • Monk
Posted October 15, 2012 - 03:14 PM
I read this right, my 06 YZ 125 rear hub will not work on my 2010 YZF 250 right?
Posted October 15, 2012 - 05:10 PM
That's correct.
  • Parx_400
Posted December 16, 2012 - 09:39 PM
Does anyone have seal sizes for the front and rear? I see the bearing sizes but need seal size.
  • GuyGraham
Posted December 21, 2012 - 07:52 AM
WR450 2008 (5ET Rear hub & Front Hub with no ribs)
front wheel seal 26 * 38 * 7
Seal in speedo 47 * 58 * 7 (on a YZ this will be different as the the seal will sit in front of the bearing and is prob same as the one above but I'm not 100%)
Rear wheel seals 30 * 50 * 6 & 30 * 44 *5
Edited by GuyGraham, December 21, 2012 - 07:54 AM.
  • GuyGraham
Posted December 21, 2012 - 07:58 AM
97 - 01 WR fronts (with the 4 cast ribs) don't fit the the 2002 & up WR's because the seal in the speedo drive of the 2002 & up is much bigger (47mm) and doesn't make contact with the hub which 42mm dia.
I don't think the drive tangs will marry up to the 2002 & later speedo drive either
Edited by GuyGraham, December 21, 2012 - 08:00 AM.
  • mikewrf18
Posted December 21, 2012 - 08:12 AM
Grayracer, excellent info, thanks for sharing. Can this be placed in the stickies for future reference?
Posted December 21, 2012 - 09:20 AM
It already is: See the Common Threads Sticky
  • mikewrf18
Posted December 21, 2012 - 09:21 AM
It already is: Common Threads: Look here 1st! Mods, Maintenance, Common Issues and FAQ's
:thumbsup:
  • Kurlon
Posted January 16, 2013 - 08:52 AM
Antique info time:
PN 4EW-25311-00-00 is the current rear hub Yamaha calls for on the following bikes:
1990-98 YZ125 / YZ250
1991-97 WR250R
1992-93 WR500R
1998 YZ400F
1998 WR400
These are 20mm axle units. Based on that, and the note from here that the 98 hub has the same sprocket and rotor spacing as the 99-up rear wheels, it should just be a matter of custom spacers to fit the new wheels to the old bikes. Brakes could be the problem though, 91 to 97 EBC says YZ/WR used the MD6011D rotor in back. 98 to 01 call for the MD6135D, after that they switch to the MD6190 series.
The 6011 is a 220mm diameter unit (6 x 8.5 bolt holes on 133mm circumference, 115mm ID)
The 6135 is a 240mm diameter unit (6 x 6.5 bolt holes on 133mm circumference, 115mm ID)
The 6190 is a 245mm diameter unit (6 x 6.5 bolt holes on 133mm circumference, 115mm ID)
metalgear.com.au does show a bike with a 220mm rotor, with the right bolt spacing to fit the new hubs though... pn 20-159. I'll try to see what it fits as it + spacers would be just the trick to put modern rear wheels on old machines.
4GV-25111-00-00 is the current front hub Yamaha calls for on the following bikes:
1992-95 YZ125 / YZ250
1992-97 WR250R
These are 17mm front axle units.
4SS-25111-01-00 is the current front hub Yamaha calls for on the following bikes:
1996-01 YZ125 / YZ250
1998-99 YZ400F
2000-01 YZ426F
These are 20mm front axle units. So in theory, 96s will swap with 97s and up...? Bearings match.
Edited by Kurlon, January 16, 2013 - 11:35 AM.
  • jerm5591
Posted January 29, 2013 - 01:12 PM
Just pick up a four rib front wheel for my 05 yz450. so I understand right the 01 spacers a good bit longer right seems like alot of space between hub and forks
  • woods-rider
Posted May 02, 2013 - 01:25 PM
Will a 2002 YZ250 smoker rear wheel fit a 2006 WR450? I am reading between the lines and it looks like it will, but haven't seen a definite answer. The front won't have the speedo prongs but should it fit and just not run the speedo?
Edited by woods-rider, May 05, 2013 - 07:50 AM.
  • GuyGraham
Posted July 03, 2013 - 10:00 AM
correct on both
  • 1stSSPZ
Posted January 13, 2015 - 09:22 AM
So, will my wheels interchange between my 13 YZ450f and my 13 YZ250s, just have to exchange spacers? Did notice the rear hubs had different part #'s. Thanks!
Edited by 1stSSPZ, January 13, 2015 - 09:23 AM.
Posted January 13, 2015 - 09:24 AM
They YZ250 is likely still using the small rear axle, so no, the rears won't interchange.
  • 1stSSPZ
Posted January 13, 2015 - 09:45 AM
Thanks Gray!
  • TrueBlueWR
Posted January 26, 2015 - 10:18 AM
correct on both
So will my 2002 yz250 excel 19" rear rim/hub fit to Replace my 2005 wr450 18" wheel?
  • GuyGraham
Posted January 26, 2015 - 11:10 AM
Yes- they both use the '5ET' hub so will interchange without any modifications
http://www.thumperta.../#entry12083242
Edited by GuyGraham, January 26, 2015 - 11:11 AM.
  • velocity1
Posted February 21, 2015 - 08:19 PM
Can you change the bearing size from a 2012 yz450 to fit a 2001 yz250 axle? I already modified the spacers on the front wheel to make it work,
Posted February 21, 2015 - 09:59 PM
If you mean the rear, no one I know of has found one yet that works.
  • velocity1
Posted February 22, 2015 - 10:59 AM
Yes i mean the rear,Thanks. I thought about machining the hub to make for the bearing fit to match my 22mm shaft.
Edited by velocity1, February 22, 2015 - 11:00 AM.
Yz250 woods questions by XRalways
  • Hot  48 replies
  • Hot  50 replies
What would you buy? by 2000YZ250
  • Hot  45 replies
  • Hot  38 replies
2005 YZ250F Throttle Position Sensor, Please Help me? by Yamaha_2005_YZ250F
Dirt Bike   Make / Model Specific   Yamaha   WR/YZ 250F
  • 7 replies
