  • Instagram
Related Garage
Yamaha WR450F (2013)
Owner: 20 A
Added on January 16, 2017
Related Reviews
Yamaha WR250F 2017
Last review by MoMike1013
PCC Motor 19"/16" Front/Rear Honda CRF150R MX Wheels Set Black Rim Red Hub 07-15
Last review by MotoX88294
Yamaha YZ250 2014
Last review by MSEG77
Yamaha WR250F 2016
No reviews available
Be the first to review this
Last review by Tommyk_55
* * * * * 3 votes
Wheel Interchange: What fits what?
Yamaha YZ450F Yamaha YZ250F Yamaha YZ426F Yamaha YZ400F Yamaha YZ250 Yamaha WR450F Yamaha WR250F Yamaha WR426F Yamaha WR250 Tires & Wheels Wheels
143 replies to this topic
  • 5valve
Posted January 12, 2010 - 02:52 AM
Argh. Read the whole thread before, don't know how it slipped by.
So in theory, it should go, so I'm going for it.
  • 5valve
Posted January 17, 2010 - 02:02 PM
Well, without heavy modding, it won't go. While presuming, that spacing sprocket/center/disk is correct, as stated, numerous other problems occur.
'98 hub bearings are 42 outer, 20 inner, type 6004.
I believe, that 42 outer, 22 inner bearing doesn't exist. Can't find it online.
Also, in the center of the hub hole, there is a moulded ring, that doesn't allow use of a bigger spacer. This ring would have to be machined out.
If 42 outer, 22 inner bearing doesn't exist, maybe 47/22 does (but at what width?)
This would also require machining the seat for the bearing from 42 to 47 or bigger)
By the way, '98 hub seals already are 47 outer diameter, which then narrows for the bearing.
So, it is not a go to shop, buy new bearings and seals, and install, option.
  • 5valve
Posted January 18, 2010 - 02:12 PM
Update.
Seems, that 44 outer, 22 inner bearing exist, even same thickness as original. It will only need 1mm of machining the hub seat.
Seals 47/22 are deliverable cheap.
Next thing is a spacer, which is shorter due to one bearing more in the '98 rim. I think I'll have it made.
  • nice400f
Posted March 01, 2010 - 07:44 PM
Hey GreyRacer,I have a 99 yz 400f and i picked up wheels for a 98 front and rear with hubs, but the hubs i found out are diff on the front and rear. the rear i sent back and they are putting hubs on the wheels from a 99 and sending it back to me, but the front bolted right up, except there is about an 3/8 inch gap between the spacer, and the fork. my uncle has a maching shop and was wondering if i could just make spacers to fit to make the front end tight? is it safe doing that? let me know. thanks.
Posted March 01, 2010 - 07:48 PM
Please re-examine this info. The answer is in there.
Front Wheels:
The front hub is the same from 1997 to 2001. Uses 20mm bearings. It can be identified by the four cast reinforcement ribs running across the hub.
2002 and up use the same hub. This hub also uses 20mm bearings. It is smooth across the center, with no ribs, and has a larger diameter at that point.
Early Front hubs can be used on 2002 and up by using the 2001 spacers . 2002 hub can be used on earlier bikes by using 2002 and up spacers.
This information applies to all YZ models from 125-450F.
  • nice400f
Posted March 01, 2010 - 07:55 PM
it says that the hubs are the same using the 20mm bearings, which do fit the axle fine, but as i said the spacers are not long enough to cover the entire axle. i see it says early hubs can be used on the 2002 and up by using 2001 spacers, but what about using the early hub on a 99? doesnt say anything about what spacers would work on that year. thanks
Posted March 01, 2010 - 08:21 PM
What it says is that the hubs are the same '97-'01. If one of yours is different than the other.....
One of your bikes does not have an original wheel, perhaps forks, on it.
  • nice400f
Posted March 01, 2010 - 08:26 PM
well i know the forks are the right ones, i just had them rebuilt, but as long as the axle bearings are the same diameter, i should be ok as far as just making the spacers a little longer on each side, to take up the rest of the space on each axle right?
  • nice400f
Posted March 01, 2010 - 08:38 PM
it looks like the 98 and 99 uses the same diameter on the bearings in the hub, but the hub in not as long as the 99 from end to end so i am hoping to just machine longer spacers to fit in the open space. should be no problem, i would hope. any objections?
Posted March 01, 2010 - 08:40 PM
Probably.
  • Reedus
Posted March 12, 2010 - 04:33 AM
Ok, heres another for ya: Looking to replace a rear rim on an 08 YZ450. It is an excel 19 X 2.15. Does excel make wheels that are make dependent? In other words, is a 19" rear rim off a kawi or suzuki going to lace up to a Yamaha hub?
Posted March 12, 2010 - 08:26 AM
Yes. The nipple angles will vary according to the hub they were drilled for.
  • Kurlon
Posted February 14, 2011 - 07:29 PM
Ok, so front hub info back to 98 has been sorted... anyone got details on the earlier generation, 90-97 front wheels? I'm curious if newer wheels can be adapted via bearing swaps or if Yamaha mucked around with more than axle sizes in 98?
  • Kurlon
Posted February 21, 2011 - 07:39 AM
92 to 97 WR250s, 92-95 YZ125/YZ250 use a pair of 6003 bearings in the front wheel. 17x35x10.
Unfortunately I can't find a 20x35 ball bearing or a 17x37 so it doesn't look like there is an easy path to put new wheels on old forks or old wheels on new forks without custom spacers/axles.
  • RM250270
Posted February 15, 2012 - 10:34 AM
So will a 02 YZ125 rear wheel fit a 02 CR125? I think but I'm just making sure before i buy the wheel. =)
Thanks!
Posted February 15, 2012 - 11:26 AM
Uh, no. Not without work.
  • RM250270
Posted February 17, 2012 - 01:54 PM
Okay.... thanks anyways man! :smirk:
  • Bandit9
    TT Titanium Member
Posted July 31, 2012 - 05:08 PM
Ok I just looked at the part numbers for the hubs. They use the same part number for both 08 and 09 rear hubs. I thought the 09+ had a bigger axle?
Posted August 01, 2012 - 07:37 AM
Hub part numbers from Yamaha:
2009 = 17D-25311-00-00
2006-2008 = 5ET-25311-00-00
  • Bandit9
    TT Titanium Member
Posted August 01, 2012 - 04:39 PM
Thank you Gray, I didn't catch the first 3.
Just for the record, the 09+ WR450 never received the new hub, 5ET-25311-00-00 right up to 2012.
  • 10 replies
How much will I battle engine temps? by 69fastback
Dirt Bike   Make / Model Specific   Yamaha   WR/YZ 250F
  • Hot  28 replies
Exactly why I hate riding trails... by RamblingRMZ
  • Hot  148 replies
What would you buy? by 2000YZ250
  • Hot  45 replies
2002 yz250 Revive with WR Transmission Guide (pic heavy) by blbiker56
  • Hot  36 replies
