1998 WR 400 Front Rim Compatibility
8 replies to this topic
  • vtisc007
Posted April 15, 2008 - 04:33 PM
I have searched up and down. I still have not found a straight forward answer. I hope someone here can help me.
I am currently on a hunt for an extra set of used wheels for my 98 WR 400.
I found the rear wheel on EBAY with minimal effort; however, the front wheel is much more difficult to locate.
My question is........Is there any other wheel that will fit?
I have noticed that there is a lot of YZ/WR 250, 400, 426, 450 wheels. Some ads claim that they will fit a wide array of years and models.
I have yet to find the front wheel for my 1998 WR 400.
Thank you.
  • Alternative
Posted April 16, 2008 - 01:53 AM
As far as I'm aware the front hub didn't change from '98-'05, so any wheel from those years' WRs should fit. The YZ hub doesn't have the drive for the odo cable but will work if you don't use your odo.
  • Frostbite
Posted April 16, 2008 - 05:38 AM
I'm not sure about the exact years, but those model wheels will fit. The 125 rim may be a bit a bit narrower.
  • vtisc007
Posted April 16, 2008 - 11:29 AM
I've got this crazy feeling that there is a difference between 1998 and 1999.
  • bg10459
Posted April 16, 2008 - 11:49 AM
See here --->>>http://www.thumperta...ad.php?t=632582
  • Alternative
Posted April 17, 2008 - 05:15 AM
The rear axle changed from a 20mm to a 22mm and subsequently the rear hub changed. The front remained the same as far as I'm aware.
  • vtisc007
Posted April 22, 2008 - 10:05 PM
This is by far the best information I have ever seen.
There is only one minor snafu.
It doesn't mention anything about WR's........only YZ's.
If I do get a YZ wheel, do I need to get YZ spacers. I'm using a digital speedometer/odometer (sensor type).
  • Frostbite
Posted April 23, 2008 - 03:10 AM
You'll need the YZ spacer for the odo drive side since you won't be able to install the odo drive with the YZ wheel.
  • zorroz
Posted April 23, 2008 - 05:51 AM
From 1st hand experience I ran a 99 front rim on my 02 Wr and I had to use the 99 spacer that the only difference cause the hub is a little narrower. So all you need to do is use the same year hub and spacer and will fit any 96 to 07 bike.
