HELP! cam change screw up!
22 replies to this topic
  • 2001YZF426Rider
Posted April 14, 2008 - 12:58 PM
Ok, i was just outside swapping the exhaust cam out for an 03 one.. When i pulled the cap off, the clip fell down through one of the holes, i could hear it rattle down. I am screwed arent i!! What do i do now? Tear down the motor?
Posted April 14, 2008 - 01:06 PM
Remove the ignition side (left) crankcase cover and look for it there. It's probably sticking to the flywheel magnets. If not, it's still in the chain tunnel somewhere. No biggie.
  • jayh300
Posted April 14, 2008 - 01:24 PM
that's where it was when i dropped mine.....stuck to the flywheel.
  • todds924
Posted April 14, 2008 - 06:27 PM
get a flashlight and a magnet. At least its worth a try before pulling the cover and flywheel. You should be able to fish it out.
  • 2001YZF426Rider
Posted April 14, 2008 - 06:47 PM
I will try that grayracer, i just had installed the lighting stator just prior to taking out the cam, so it will only take a few minutes.. Hopefully it is there.. There is only one clip correct?
Posted April 14, 2008 - 06:55 PM
I don't think I own a magnet that could pull something off the flywheel. :confused: :thumbsup: :thumbsup:
  • 2001YZF426Rider
Posted April 15, 2008 - 10:35 AM
The only thing is i am thinking, is that it fell down through the hole underneath the cam cap. Do you think it would still be near the flywheel? If not, could i get into the crank without taking they cylinder off? Like if i take out the clutch etc. Im going to look on the flywheel either tonight or tomorrow morning.
Posted April 15, 2008 - 01:01 PM
It cannot have gotten into the crankcase directly from the top of the cylinder head, no matter what. If it went down that way, it's stuck in the chain, or on the flywheel.
  • 1rkcooper
Posted April 15, 2008 - 07:27 PM
I have done this twice, get a flashlight and extendable magnet and fish it out. As long as it didn't get to the flywheel you should be able to carefully fish it out.
Good luck
  • todds924
Posted April 15, 2008 - 07:40 PM
I don't think I own a magnet that could pull something off the flywheel. :ride: :thumbsup: :confused:
Are you telling me you've never had a clip fall down there before????:thumbsup: I have, and when it happens I can usually see it down there with a flashlight and extract it with a magnet. If i'm not so lucky, then the cover comes off. Its really no big deal either way.
  • todds924
Posted April 15, 2008 - 07:41 PM
You mean like those big electromagnets they use at the metal scrap yard????
Posted April 15, 2008 - 09:22 PM
Uh, well, yes, I am telling you that. Junior, however, ignored my advice and dropped one once. He got lucky and it hung up on the chain, so it was easy to fetch.
I've done a lot of other stuff stupid enough to match that, though, just not lately.
  • 2001YZF426Rider
Posted April 16, 2008 - 05:16 AM
Thanks guys! I found it right behind the stator!! Phew!
One more question, when installing the 03 cam, is the only way to time it by having 14 pins between the dots? And obviously with the motor at TDC? I followed the directions in the common threads, and the back of the cams look to be symmetrical..
  • jbrooks26
Posted April 16, 2008 - 07:29 AM
That is correct, condensed but correct. You need to be certain the engine is at TDC, your intake cam timing mark lines up with the top of the head and the lobe on the intake cam should be facing away from center, then count your pins between the upper timing marks to be 14. If you meet all of these conditions then your timing will be correct. Don't forget to time your intake cam with the chain slack removed by pushing on the chain through the tensioner hole or you will be pulling your hair out trying to figure out why the timing is changing when you install the tensioner. Hope this helps,
Josh
Posted April 16, 2008 - 09:15 AM
Josh
Perfectly right.
  • tnl
Posted April 16, 2008 - 06:19 PM
How about dropping a # 27 torx driver bit into the case while removing the stator?
  • 2001YZF426Rider
Posted April 16, 2008 - 06:58 PM
Well i checked the timing with the tensioner in and it seems just fine.. This is how it looks..
  • thumpyz
Posted April 16, 2008 - 07:20 PM
I am not exactly sure, but i think the cap needs to be tight before you set the timing, otherwise the cam could pull out of the head and you might not be dead on.
  • tnl
Posted April 16, 2008 - 09:07 PM
I don't see the 2nd exhaust timing punch mark? As long as the cam cap cover is set flush it can be checked
Posted April 16, 2008 - 10:28 PM
If that exhaust cam is for a YZ450, then the timing is correct. The 9:00 o'clock mark on a 450 cam cnnot be used to time it in a 426 head.
  • On Yesterday, 06:20 PM
  • 0 replies
  • Hot  36 replies
  • Hot  50 replies
