Airbox washing?
22 replies to this topic
  • kyle450rider
Posted April 14, 2008 - 09:39 AM
Anybody ever do this? Mine is really getting messy from all the filters leaking gunk in it. I am probably going to buy a twin air cover to power wash the inside.
Posted April 14, 2008 - 10:00 AM
I don't. For one thing, my air filters don't leak gunk because I pre-oil them and hang them over a can for 24 hours before installing them. When I change out the dirty filter, I mop out the air box with a disposable shop towle and solvent (mineral spirits).
  • ktmburty22
Posted April 14, 2008 - 11:47 AM
i wash mine out everytime i wash my bike,just to get all the crap out if there is any,my filters dont leak though,got the air filter wash cover and give it a good hose out and shes spotless.
  • StPeters21
Posted April 14, 2008 - 02:04 PM
i take the whole sub frame off and wash it out periodically. make sure its dry before you put it back on. i definately get some dirt and dust in the box area, not in the boot. its very dusty in the midwest during the summertime.
  • USED YZ426F
Posted April 14, 2008 - 02:07 PM
When I get the subframe off, I rubber band a plastic bag over the carb input and use a toilet brush to clean the area around the upper and lower spring perch. Much, much easier to get all of the dirt and mud out of there with the subframe off.
  • CaptainKnobby
Posted April 14, 2008 - 02:56 PM
I do the same thing......Just oil your filters(if you have more than one)and let them dry for a day.I have five NO-Toil airfilters and wait until I have four of them dirty and then clean all four at the same time and then I let them dry and then oil all of them at the same time. When it comes time to change the filter I have one ready to go in. By the time I get to the fourth filter it has had nearly a month to hang. I have never had an issue with gunk or excessive oil in the breather.:thumbsup:
  • Markopolo400
Posted April 14, 2008 - 03:10 PM
I have an Acerbis air boot wash cover, I spray the inside of my airbox with Simple Green, hit it with my pressure washer, and blow it dry with my blow gun on my air compressor.
My airboxes look new. :thumbsup:
  • kawazooki_doc
Posted April 14, 2008 - 03:17 PM
I use to fight and struggle cleaning mine untill I learned it is way easier and faster to just take the sub frame off and clean it that way. As with anything else on a dirt bike it's easier to clean it every time vice waiting for it to build up. If you have "gunk" in your box from your filter you are using way to much filter oil. I use to have this problem untill I switched to the spray oil. Easier to control amount of oil without wasting. When I was using to oil from a bottle I could only get 2-3 filters out of it, with the spray I get at least 7.
  • steve_97060
Posted April 14, 2008 - 03:30 PM
I have the Twin Air boot cover, I spray the box with simple green and hose it out, then wipe it dry with a shop rag.
I also use the PJ1 spray on filter oil, it goes on nice and you can control the amount better..
  • CaptainKnobby
Posted April 14, 2008 - 03:36 PM
I use the 1/2 gallon bottle of NO-Toil oil now but when I was useing the 16oz bottle I would pour all of it in a ice cream bucket that comes with a lid and dip my filter down it and squeeze out all the excess. Put the lid back on and store it in the closet in the house where it is room tempture which is about 70 to 75 degrees. I could get around 7 filters out of it,but you will waste alot if you do not do it this way because if you just pour the oil over the filter and let it drain in a bowl or something and after squeezeing out the oil of the filter and then pouring it back into the oil bottle you will leave some oil in the bowl and after about three changes there would be enough oil left over to oil another filter or two.
  • almostinvincible119
Posted April 14, 2008 - 06:45 PM
dude, all you cool guys who just PULL YOUR SUBFRAME OFF must own something older than an 06+
cause its a straight up beeotch to put that boot back on.
i only pull that thing when i got to
Posted April 14, 2008 - 06:53 PM
Almost,
Try this next time:
Pull the sub frame as usual, but before you reinstall it, remove the air box and install it onto the carb by itself. Then slip the sub on around/over it and bolt everything back up.
:thumbsup:
Posted April 14, 2008 - 07:15 PM
ohh i do that already.
still a bitch, and not worth takin off to clean your airbox
i use a airbox cover if it gets really grimey. but everytime i change a filter i spray some brake cleaner on a rag and wipe it out
  • nap__kxf
Posted April 14, 2008 - 07:35 PM
yeah, the 06+ is a pain to put the airboot back on but my dad and i figured out if you take off of the top bolt for the shock you can move the shock out of the way (it was in the way for us) and the airboot slipped right on, then tighten that and put the shock bolt back in and put the subframe back on.
but back to gunky airbox, mine is gunky as all hell. i'm a failure at oiling air filters, i always over-oil them. i can never get it right. :thumbsup:
  • BergArabia
Posted April 14, 2008 - 11:51 PM
I also clean the airbox every service.
Just wiping it out with a towel and solvent. Works for me. Takes a bit of time but then, getting the oil to drain out completely takes some time so that is when I do it.
Posted April 15, 2008 - 07:35 AM
i dont let the filters sit overnight, i just oil it lightly, install and ride. i change it every ride anyways. so light oil for me is the ticket, unless im riding sand.
Posted April 15, 2008 - 08:45 AM
That approach won't work here. Too much fine dust, especially in the deserts. The only hope of keeping it out is to have the filters thoroughly oiled all the way through with an aggressive filter oil. To see it you would swear you couldn't grind rocks into that fine a powder. The stuff hangs in the air like smoke, and weighs next to nothing. Not so bad on a well groomed track of course, but....
Me:
Junior:
  • Ga426owner
Posted April 15, 2008 - 01:06 PM
I guess I am a slack@$$....I spray simple green (litely) 50/50 mix with water directly into the airbox (all over)while dirty filter is still installed...wait 1min and blast it with my hose for approx 2-5sec. I then let all water drain and redo again then remove wet nasty airfilter and then papertowel out all water....there is only a few drops in the airbox lower section each time. Remember no more than 2-5sec....otherwise water level rises too much to go into carb.....remember it drains out....just do not get water level to rise past lower lip (bottom of airfilter).....remember oiled filter keeps most water out
or just get smart and buy the darn Twinair cover....:thumbsup:
Posted April 15, 2008 - 01:16 PM
If you don't spray it directly, or run the engine with the wet filter, this may work well enough, but oiled foam filters don't stop water at all.
  • Wiz636
Posted April 15, 2008 - 01:39 PM
I rarely clean mine. :thumbsup: Pretty much only when I have the subframe off for something else.
  • Hot  30 replies
  • On January 15, 2017
  • Hot  113 replies
  • Hot  38 replies
  • Hot  28 replies
