Lean or rich?
8 replies to this topic
  • 080
Posted April 14, 2008 - 05:43 AM
Rolling (not blipping) the throttle out of a corner and it stalls. Is it to rich or lean on the pilot?
Posted April 14, 2008 - 06:01 AM
At what point in the throttle does it stall?
Are you riding a gear high out of the corner?
  • 080
Posted April 14, 2008 - 11:09 AM
It stalls randomley just off idle as I'm starting to get on the gas. The first time I figured I was getting on the gas to quick being my fault but after a few more times I realized that wasn't the case. It stalled once going into a corner just as I was letting off the throttle and starting to get on the brakes. If it was a 2strk I would just go leaner on the pilot/air screw but being these have accelerator pumps, leak jet etc.... I'm a little confused on where to start first. I do tend to ride my bike in the lower to mid part of the power if that is considered riding a gear high but am on it pretty hard out of corners and up hills.
Posted April 14, 2008 - 11:16 AM
I would check the float level first.
  • William1
Posted April 14, 2008 - 02:15 PM
+2 on the float level.
Pilot and fuewl screw is for idle only.
If the float level is right, you may want to try a different leak jet. While you have the bowl off, make note of the current one in there.
Posted April 14, 2008 - 02:19 PM
The pilot circuit runs everything at an idle, but also has a huge influence on whether the engine returns to idle properly from speed, and in how it transitions from idle to open throttle, when the main circuit starts working.
However, I don't yet think it's the culprit here.
  • 080
Posted April 14, 2008 - 03:55 PM
I will give it a look tomorrow and let you know. Thanks.
  • BASSic
Posted April 14, 2008 - 04:57 PM
When was the last time you cleaned the carb? Did the bike run fine before and just recently start doing this?
I've had some similar symptoms a few times, and after pulling the float drain and finding a bunch of gunk I determined I need to pull the carb and clean it.
  • todds924
Posted April 14, 2008 - 06:20 PM
My 08 did the same thing. I installed a 50 leak jet and its good now.
  • Hot  38 replies
  • Hot  113 replies
  • Hot  47 replies
  • Hot  30 replies
