Second oill change
10 replies to this topic
  • Windseeker
Posted April 10, 2008 - 02:09 PM
You might find this interesting - that's the second oil change on a 08 YZ450F. I took the the scotts filter out to have a close look at the debri and found this monstrous piece of metal among smaller non metallic crap... Never thought such things could travel inside a healthy sounding and pulling bike.... Or should I start to worry?
:thumbsup:
  • USED YZ426F
Posted April 10, 2008 - 03:17 PM
Did that come out of the inside of the filter? Or was it stuck to the outside like it is in the pic?
It looks like a small piece of wire or something similar in the pic.
Does it look like that in real life? Or is it more of a metal sliver?
  • todds924
Posted April 10, 2008 - 03:20 PM
:thumbsup:
Wow! that looks pretty extreme. How did it look after the first oil change? And were you still using the stock filter at that point? I have seen some CRF filters that looked like that which had the crankshafts going out:eek:
  • biznet1
Posted April 10, 2008 - 03:28 PM
I believe the flakes are normal for a new motor. The larger piece probably dropped in there during the building process. I would pull the filter every hour or so riding time and check it until you're sure that's all it was. It doesn't look like a mechanical defect to me, because if it was, your bike would probably have grenaded by now (assuming 2nd oil change equals 10 hrs).
  • Windseeker
Posted April 10, 2008 - 08:58 PM
1) It was outside on the filter surface.
2) loked like not wire but the edge of hole sawn off thingy...
3) it was (it is) a new metallic scotts filter - it was its first service
4) bike has only 5 hours....
5) inside the filter was nice and clean - I made sure when I washed the filter the gas that I washed the otside with does not get inside.... Then I used pressured air to dry the filter (fron inside out only)
6) yeah - probably checking that filter every hour would be a wise thing....
  • Windseeker
Posted April 10, 2008 - 08:59 PM
yep - the correct word is metal sliver... :thumbsup:
Posted April 10, 2008 - 09:47 PM
None of it looks particularly worrisome to me. This sort of thing is not unusual for a brand new bike, really. Check again next oil change.
  • Slinkyman16
Posted April 10, 2008 - 10:12 PM
you will be amazed at what stuff you will find after the first few oil changes. it took about 3 for all my slivers and debris to be non existent. and you were smart and bought a good oil filter in the first place, so you cought even more then i did..
  • clutchless
Posted April 11, 2008 - 07:37 AM
i usually use paper oil filters for the first 3 -5 oil changes then switch to scott's. Change the oil after every ride. heard that paper filters a little better then the scotts does and are better during the break in period.
Posted April 11, 2008 - 10:12 AM
Review this, then decide:
http://www.thumperta...297#post4676297
  • clutchless
Posted April 11, 2008 - 10:28 AM
no thanks. all good.
