fuel screw help
3 replies to this topic
  • hoople
Posted April 10, 2008 - 01:57 PM
Puttin an adjustable fuel screw in and got the parts mixed up
does it go - washer,o-ring,spring then screw (i think)
or
o-ring,washer,spring then screw
thanks for the help, i'm an idiot:excuseme:
  • yamageezer
Posted April 10, 2008 - 02:08 PM
It's all good. O-ring, washer, spring, screw.
  • hoople
Posted April 11, 2008 - 01:21 PM
Just put in a white bros adj fuel screw, had a 48 pilot jet and fired it up to adjust the idle mixture, the engine revs faster the further I cranked the screw in.
Took out the 48 pilot and put in a 45, same thing screw the fuel screw all the way in keeps revving faster
Do you think I should go leaner yet? It should cough and sputter when screwed all the way in shouldn't it?
  • William1
Posted April 11, 2008 - 03:11 PM
If the bike continues to run with the fuel screw all the way in, then you need to go leaner on the pilot.
The alloy screws are sometimes poorly machined and it is not uncommon to have to go as much as two jet sizes smaller than with the stock or properly made fuel screw (The Kouba Brass or Kientech Stainless Steel).
