asked the dealership
19 replies to this topic
  • wartsnuff
Posted April 10, 2008 - 09:00 AM
Hey Guys,
was looking for an opinion,
i just bought my 08 WR450F bike got about 75km's on her now.
i was riding with a buddy little slower, as he has a 600 quad.
he noticed that my pipe was cherry red for about 6-8" from the jug.
i have read thats a sure sign your bike is running lean on this web site.
my dealership (witch bty is excellent, do fantastic work on my APEX sled)
siad it is normal not to worry about it. ??? should i just enjoy the bike ? or
should i be concerned ?
I have done nothing to this bike.... yet. i have a throttle stop coming and i guess the grey wire trick and something in the muffler to be done so i am told to wake up these bikes.
cheers
Warts
  • KennyMc
Posted April 10, 2008 - 09:07 AM
Here in the States the bike's come notoriously lean. Check out the jetting info that other people are using.:thumbsup:
http://www.thumperta...ad.php?t=411240
  • hoople
Posted April 10, 2008 - 09:15 AM
Hey warts, picked up my 08 and did the mods right away and my pipe does not get red.
Removed ais, grey wire mod, removed snorkel from air box, throttle stop & re-jet, and put in PMB exhaust insert and runs great
  • wartsnuff
Posted April 10, 2008 - 09:26 AM
whats the AIS ??
what if i want the snorkel ? will it do anything leaving it on ?
you did have to REJET ? where do you live ? in canada ? what jets did you use? my 08 came with some extra jets ??? did you use them ?
what about the cold temps right now ? could that be my jetting problem ? its like 0 - +5 deg C here not very warm.
PMB exhaust insert ? where do i get one ? how much did you have to pay?
thanks bunch... only owned the bike for a week... :thumbsup:
so sorry for the bombardment of questions
Warts
  • drtbk4ever
Posted April 10, 2008 - 09:39 AM
Warts,
The first thing I would do is to re-jet the carb.
Try using the search feature on the upper right hand corner. All your questions have been answered before.
The biggest tip I can give you is to read read read and then break out the wrenches. Get to know your bike and how to maintain it. The knowledge will save you tons of money and help you to get the bike running the way you want.
  • face_plant
Posted April 10, 2008 - 09:59 AM
lean is mean
its normal
  • wartsnuff
Posted April 10, 2008 - 10:01 AM
Warts,
Thanks, i have ordered the AIS removal kit from this website.
I am not sure about the rejet yet. i will do the throttle stop, grey wire mod, and exhaust insert and the AIR removal.
but i am not sure what jetting to use. i do not wanna burn down my brand new toy :thumbsup:
cheers thanks for the advise. i have been searching... but the jetting seems to be different for everyone. so its back to trial and error that worries me.
anyhow thank again
cheers
Warts
  • hoople
Posted April 10, 2008 - 10:20 AM
I'm from saskaton, you don't need the exhaust insert but at least take the smallest baffle out of the exhaust tip.
I used a 168 main jet, dtr - 4 needle, 48 pilot jet, 45 leak jet and 110 air jet
Some of these jets came with the bike (attached to the owners manual)
its not a 2 stoke so dont get worried about burnin it down
  • wartsnuff
Posted April 10, 2008 - 10:34 AM
Thanks man, thats what i wanted to hear :thumbsup:
now i have a bunch of jets that came with my owners manual.
but it sounds like you still had to buy some ? from the dealership?
thanks a bunch
cheers
Warts
  • timoyz1
Posted April 10, 2008 - 10:40 AM
Get a JD Jet Kit. My pipe was always glowing and I had detonation so I started runnig 100 octane. Detonation went away, but pipe continued to be red now my screen in my spark arrestor has eaten away. Rejetted and all problems solved. Lean is mean until you melt a piston.
  • wartsnuff
Posted April 10, 2008 - 10:55 AM
do i buy the JD jet kit from this site ?
cheers
Warts
  • KennyMc
Posted April 10, 2008 - 10:59 AM
cheers
Warts
Yeah, I got mine here.
http://shop.thumpert...ting_jetkit.htm
  • wartsnuff
Posted April 10, 2008 - 12:34 PM
Thanks :thumbsup:
next pay day i will buy this :thumbsup:
  • matt4x4
Posted April 11, 2008 - 04:12 AM
Your pipe will be red - it's normal - the pipe is titanium and very thin and therefore gets red hot quick, usually, you notice this on overcast days or in the evening/night or inside the garage. It'll be brightest when you're sitting due to the lack of airflow that helps cool it.
  • timoyz1
Posted April 11, 2008 - 04:28 AM
A little red, yes. But I'm talking you could see red after running hard for a while. I never thought about checking a plug since it was a brand new bike, straight from the dealer. Maybe it's different here in So Cal, but listen to the voices here, Yamaha ships them lean to pass emissions and suspension packed with very little grease.
  • wartsnuff
Posted April 11, 2008 - 05:57 AM
its no longer red...
its seems maybe breakin in the motor was extra hot.
anyhow another question. i was looking at my bike its an 08 model year.
the AIS system is not near the carb anymore... its under the gas tank near
the front forks. i purchased the AIR blockoff from this site. can anyone confirm that it will work?
cheers
Warts
  • KennyMc
Posted April 11, 2008 - 06:43 AM
cheers
Warts
You will probably need to supply your part# so someone who also purchased the block-off kit from here could confirm. I got the GYTR kit from Yamaha since it came with the new throttle stop screw.
  • wartsnuff
Posted April 11, 2008 - 07:21 AM
Hey there
P/N INT_THUMPERTALK_AISSRK450-7
desc : ThumperTalk AIS Smog Removal Kit 2007+ Yamaha WR450
let me know if this helps ya :thumbsup:
cheers
Warts
  • timoyz1
Posted April 11, 2008 - 08:55 AM
cheers
Warts
That's where my AIS is and it's an 07 so it should be the same. I just cut a piece of 12 ga. and put it between the head and the AIS tube flange. Then took JB Weld and sealed up my AIS unit, all 3 ports, and plugged all the hoses back in. Would have liked to taken the whole thing off, but thats the price of living with CARB. Be ready to drain your antifreeze, it makes the job a whole lot easier.
  • KennyMc
Posted April 11, 2008 - 09:04 AM
Yeah, I have been thinking about putting mine back on:foul: Need to get some JB Weld.
