Is it ok to desmog without a rejet on XRL?
9 replies to this topic
  • Memnok
Posted April 09, 2008 - 04:55 PM
I will be doing both, but I want to get a head start and get the desmog done now. I think I read that you only need to rejet with a new pipe, or air box mod. I only ask because I need the bike to ride to work in the AM. I’ll be ordering the jets in the near future.
  • RipperFox
Posted April 09, 2008 - 05:07 PM
Smogification only injects air in to the exhaust to finish burning air/fuel gasses that didnt burn in the cylinder. thus the "pop" on deceleration.
It does not effect the air/fuel ratio going to the intake.
But consider this, the bike is lean from the factory. Designed lean to pass emissions standards. So in the opinion of most people you will talk to on hear, you already need to rejet from day one.
So to answer your question. No you dont have to because of the DeSmogificaiton. But you should because your bike is lean already, If thats ok with you Martin?
  • Memnok
Posted April 09, 2008 - 05:09 PM
Thanks, I have come to the same conclusion from reading this forum. I will be ordiering the jets (tonight I hope).
  • martinfan30
Posted April 09, 2008 - 06:24 PM
You'll be ok with doing the smog removal for now.
  • Memnok
Posted April 09, 2008 - 07:21 PM
And one last pre-install question... Do you need to use a gasket material with the smog block off plate?
http://www.4strokes....smog/pic12.html
  • martinfan30
Posted April 09, 2008 - 07:23 PM
A light coat is ok. Mine didnt come with gaskets... Then again its been three years since.
  • Memnok
Posted April 09, 2008 - 07:31 PM
Thanks! Mine did not come with any gaskets either, and there is no mention of gaskets in the instructions, but I was not sure if I should run out and buy some or not.
  • martinfan30
Posted April 09, 2008 - 07:32 PM
I dont remember doing any of that. I beleive I just bolted the plates up. From that pic you linked, it looks like there is a copper gasket. Just look closely when you pull it apart.
  • Purcell69
Posted April 10, 2008 - 02:18 AM
My kit did not come with gaskets and I installed the plates dry. I did not see any gasket material in the smog tubes when I removed them, so I figured I was okay. It's been almost 1,500 miles since I desmogged and I have not seen any indication of a leak. If you don't have any gasket material, you're probably still ok.
-Joe
  • Memnok
Posted April 10, 2008 - 06:18 AM
I looked when I pulled it off and there was nothing, so I just bolted the plates on dry, same as factory. Seems to be working ok! :thumbsup:
  • 4 replies
Honda XR650L 2016
  • 0 reviews
Washington
  • Hot  32 replies
  • 17 replies
