03 YZ450 with 13.5 Jetting Issues
4 replies to this topic
  • OUCR250R
Posted April 09, 2008 - 04:47 AM
I just got done doing a complete rebuild on my bike. I replaced the crank, cylinder, head, valves, springs, retainers, and cams (yamaha oem). I also installed a wiseco 13.5:1 piston in search of more power. The carb has never been apart and is completely stock save for a msr fuel screw. My question is does anyone have any good jetting setup tips or a good baseline to start from? My bike seems to be running incredibly lean. I haven't ridden it yet, only started it a few times to heat cycle it. Any help would be greatly appreciated! Thanks guys.
-Paul
  • OUCR250R
Posted April 09, 2008 - 06:32 AM
Even anyone with a setup similar to mine would be helpful. Or at least a hint as to what changes I will need to make. I am assuming I will need to richen up the main, but I am not sure about the pilot. Any help would be appreciated.
Posted April 09, 2008 - 07:48 AM
Why do you say it's lean?
  • OUCR250R
Posted April 09, 2008 - 07:56 AM
Because it is backfiring really hard when I let off the throttle, and typically shoots a 3-4" flame out the exhaust when it does this. I have tried adjusting my fuel screw, but have had no luck getting the backfire to go away.
Posted April 09, 2008 - 08:17 AM
Check the exhaust system for air leaks first. If you are convinced that there are none, then go up a step on the pilot jet.
  • Hot  28 replies
  • Hot  30 replies
  • Hot  47 replies
