07 XR650L finally "uncorked"....
4 replies to this topic
  • rotary16
Posted April 08, 2008 - 07:48 PM
Finally did it. :thumbsup:
Uni filter
DJ jet kit (also drilled out two outside holes in slide and ground off stop tab)
FMF Q2 slip on
Removed smog pump
Fired right up. Ran VERY well. Warmed up easily. WELL worth the efforts.
Only issue, and this is small, is that there is an ever so slight stumble on initial accelration from a dead start. Barely noticeable.
I did fiddle with the mixture adjustment, I could not discern a difference by moving the screw several turns in either direction. Is that normal?
I only replaced the main jet (165). Is there any benefit to replacing the pilot jet?
Thanks in advance.
  • AaronBrown
Posted April 08, 2008 - 08:48 PM
I had the same problem with my Dyno Jet kit on my L until I installed a 55 pilot jet.
  • Motosprtman
Posted April 09, 2008 - 05:18 AM
Me too on my 05 XR650L when I installed a DJ kit, had ot go back and install the 55 pilot, after that all is well :-)
  • Denn10
Posted April 09, 2008 - 06:08 AM
yeah you need to change your pilot also, like a whole new beast! when you change your mixture screw that much without any noticeable change thats tells you your pilot is off usually.
  • martinfan30
Posted April 09, 2008 - 08:42 AM
Yeah, richer pilot or go to a pumper.
  • Hot  35 replies
  • 22 replies
  • 4 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
