Leaking Oil on '07 450
5 replies to this topic
  • jcolborn48
Posted April 08, 2008 - 04:05 PM
I got finished with my ride yesterday, and noticed the left side of my bike was oil splattered, my tire looked like only the left side was armor alled, and my buddy who was behind me front fender and number plate was splattered with oil. However, there is no oil leaking out of the engine, could it have been coming out of the overflow tube (or whatever it is called). I slid out and layed my bike down, could that have anything to do with it? I checked my oil today, and the level is fine. Any thoughts? :thumbsup:
  • William1
Posted April 08, 2008 - 04:44 PM
Well, it came from somewhere. If your oil level is fine then???
When you layed it down, you may of had a little oil end up in the breather tube, which subsequently was expelled on your buddies bike and yours.
Clean both bikes, go for a ride. If no more signs of leakage, then that is what it was.
  • 426 NOOB
Posted April 08, 2008 - 04:59 PM
If I had to guess, it was chain lube. When I ride my whole left side of the bike is coated in it. An easy way to tell is if its under the rear fender, and smell the oil. You will be able to smell if its chain lube or oil. Just my 2 cents.
  • BergArabia
Posted April 09, 2008 - 08:08 AM
Was thinking the same,
You would only get that much out the breather if it was grossly overfilled, like maybe 1.5 litres instead of 1.
  • jcolborn48
Posted April 09, 2008 - 08:12 AM
Yeah, I ws going to clean everything up and take it for a ride and see if it happens again. Thanks for the input fellas.
Posted April 09, 2008 - 09:01 AM
The '06 and later models, unlike the '03-'05, have NO room for extra oil, and any significant overfill at all can cause oil to be expelled from the breather. This occurs when the additional oil is returned to the tank, but finds no room there. That in turn causes oil to be forced out of the tank through the pressure balance tube (right side of the bike) back to the crankcase, where it raises the oil level higher than the level at which it is intended to operate.
  • Hot  30 replies
  • Hot  113 replies
  • Hot  47 replies
  • On January 15, 2017
