The hole story
9 replies to this topic
  • Kinsman
Posted April 07, 2008 - 06:31 AM
I parked the bike (650 L) and did not use my normal 'piece of wood under the sidestand' trick.
Down she went, and the gearshift put a nice crack in the side cover. Damn.
Is the fix as simple as getting a new cover, draining the oil, and swapping them out? Anybody know where I can get the parts cheaper than Honda?
  • husky123
Posted April 07, 2008 - 07:52 AM
The "hole" story....that's gold! Anywho's a pretty simple fix as long as a million tiny pieces didn't go inside than yes an oil drain should be fine. You might want to take the cover off and inspect it though.
www.servicehonda.com has pretty decent prices.
  • XR650L_Dave
Posted April 07, 2008 - 08:17 AM
If its only cracked you can pull it, clean it in and out, and epoxy a piece of stainless over the crack- stronger than new, and the stainless will help keep it from happeneing again.
If its not evel leaking, you don't have to pull it off to epoxy a piece on.
If you do swap the cover, its pretty much as you say, you just need to swap the stator over.
Dave
  • Kinsman
Posted April 07, 2008 - 09:02 AM
Well, it looks like a crack rather than a hole, but it's leaking out pretty good. Drip...drip...drip... I would not want to ride it anywhere like it is.
I don't want to hurt the bike or have it strand me way back in there someday, but I like the epoxy idea. What type epoxy would be good to use? I have some J-B weld. Strong enough?
  • evomx971
Posted April 07, 2008 - 09:20 AM
There are probably a lot of opinions, but I think JB Weld would work perfect for fixing it. Sand down to the bare metal where you'll be using the JB. I JB Welded a piece of 1/8" thick aluminum over that area on my XRL to prevent just that same thing from happening.
You won't even need to take off the cover if you don't think any pieces came loose inside and it isn't distorted enough to have moved the stator around in there and messed up clearances. The stator attaches to the cover on the XRL.
  • WR TOM
Posted April 07, 2008 - 09:28 AM
A suggestion to prevent a reoccurence of the tip over, I welded a large washer on the bottom of the kick stand on my 650 L. Problem solved, no more tip over.
  • Kinsman
Posted April 07, 2008 - 01:03 PM
That's a good idea; would have to be a big ol' washer I would imagine.
Thanks for the replies guys....JB weld it is.
  • lifeinthesouth
Posted April 07, 2008 - 01:09 PM
DOes anyone make better case covers for the BRP
  • martinfan30
Posted April 07, 2008 - 04:18 PM
http://www.thumperta...650l case cover
This is an old thread, but has info/pics for a home made remedy. Also look into getting an MSR shifter. They are VERY stout, and dont bend like the stocker.
I think mine was 25 bucks on ebay.
  • lifeinthesouth
Posted April 07, 2008 - 05:11 PM
that's killer... my next rainy day project; hopefully sooner than later, there's already a few gouges in there.
