Help with servicing forks????
4 replies to this topic
  • tarlint
Posted April 06, 2008 - 08:42 PM
Quick question................
I am new to riding bikes and I have a 2000 WR400. My left fork is leaking fluid and I need to service them. My question is how tough will it be to do this job? The local dealer is charging $100 labor and then parts are about $50. The problem is they are 3 to 4 weeks out on time.
I dont want to be down that long with the season just starting and I am pondering trying it on my own. Are they any special words of advice for me, tools I need, etc???? I have the manual and mechanically I can figure it out if it is pretty straight forward.
Thanks in advance for your thougths!
  • groundpounder450
Posted April 06, 2008 - 08:45 PM
here ya go:thumbsup: http://www.thumperta...ad.php?t=625393
  • tarlint
Posted April 06, 2008 - 09:06 PM
Thank you, I will check these out first thing tomorrow and get it done. I appreciate the help.
  • byggd
Posted April 07, 2008 - 04:16 AM
How badly is it leaking? Have you tried the 35mm film cleaning trick? It worked great on my bike. Then I installed seal savers, no more leaks!
  • justbackitin
Posted April 07, 2008 - 06:08 PM
I just replaced my left fork seal. It took me about an hour an new seal and $10.00 worth of oil. The only tool you really need is a seal pusher to properly punch the seal into the fork leg. Do a little searching around, and make sure you look in the yz section of TT. You should find some step by step instructions.
