Subframe for rear fender on XR650R appears to be bent
5 replies to this topic
  • michaelschorpp
Posted April 06, 2008 - 05:48 PM
Hi There,
I purchased a 2000 XR650R 6 months ago and noticed that the rear fender was tweaked to one side, as if the subframe was bent. The XR650R FAQ makes mention of this, and states it can be fixed with a 5 ft crowbar. Is there a recommended technique?
Mike.
  • dylanr
Posted April 06, 2008 - 06:01 PM
I think they come bent from the factory, i used a big pipe, but its still not quite right.
Good Luck
  • Billahjack
Posted April 06, 2008 - 07:04 PM
You have to jump it and crash land just right with the rear left side of the bike landing first to get it straight. Of course, you will need a new fender after you complete this process.
  • scalejockey
Posted April 06, 2008 - 08:21 PM
It's kinda a 650r thing,As you look at it from the rear it's a little to the left.Yes?And the tire has made some black marks above the pipe on the fender,Yes? Now for the fix.. loosen the three mount points and the silencer then push it to the right and tighten down.I will most likely do it again but it's good for now.Really..
I call it "personality" of a bike.
  • cb60130
Posted April 06, 2008 - 10:05 PM
I've loosened my sub frame and tried the pry bar method too...to no avail.... just learned to live with it. I believe someone called it "Side Mileage" So that's what I call it!!!
  • XR4DEZ
Posted April 07, 2008 - 09:35 AM
It'll just creep back to looking bent in a few rides. When the center of the fender is over the side of the tire, then it's bent.
  • Hot  186 replies
  • 22 replies
  • 3 replies
  • Hot  35 replies
  • 9 replies
