Valve Shim Calculator and Log
11 replies to this topic
  • CORider63
Posted April 05, 2008 - 08:21 PM
I put together an Excel spreadsheet that calculates the required valve shims for a 4- or 5-Valve motor. Is there anyone who is planning to check their valves in the near future who would be willing to test it out and provide me with some feedback?
If so, please PM me with your email address and I'll send you a copy.:thumbsup:
  • byggd
Posted April 07, 2008 - 03:56 AM
Isn't that the same thing that's in the factory shop manual? :thumbsup:
  • CORider63
Posted April 07, 2008 - 04:08 AM
Not exactly. The manual is a simple chart.
  • Demo_Slug
Posted April 07, 2008 - 11:00 AM
the chart worked good for me. what else does your spread sheet do?
  • CORider63
Posted April 07, 2008 - 11:08 AM
It allows you to use shims with steps other than the Yamaha .05mm step shims, (i.e. the Honda .025mm step shims), provides part numbers for the correct shims from Yamaha, Honda or Hot Cams, and provides a log of all shim checks/changes.
  • byggd
Posted April 07, 2008 - 11:40 AM
My bike isn't due for a check and adjust but i'm always interested in a cheat sheet :thumbsup: maybe give it to the mod to add the the sticky :thumbsup:
  • CORider63
Posted April 07, 2008 - 11:57 AM
I want to make sure that it gets thoroughly tested before being posted.
  • pquirk
Posted May 04, 2008 - 04:24 PM
Where'd you get the specs for your spreadsheet? The manual says .005 for intake and .011 for exhaust
  • CORider63
Posted May 04, 2008 - 06:41 PM
From the manual, in millimeters (since all of the shims are measured and marked in millimeters):
Valve Clearance (Cold)
IN .10 to .15 mm (.0039 to .0059 in)
EX .20 to .25 mm (.0079 to .0098 in)
  • pquirk
Posted May 05, 2008 - 04:17 PM
LOL, sorry man, I actually wasn't even looking at your spreadsheet. I've been looking at a few different ones to compare results and got confused about which was whose. One had some numbers that didn't make sense to me, but it wasn't yours.:eek:
  • justbackitin
Posted May 05, 2008 - 06:13 PM
Excuse me for my ignorance, but Honda shims fit our yamahas? What models of Hondas?
  • CORider63
Posted May 05, 2008 - 07:38 PM
CRF-450R/X's are also 9.48mm diameter shims and CRF-250R/X's are 7.48mm diameter shims.
