yz400 stator question
15 replies to this topic
  • frankllynn
Posted April 05, 2008 - 07:12 PM
Does anyone make a high output stator for the 98 yz400. I have found a 50 watt stator at rmstator.com and thats all. I have looked at ricky stator and baja designs. No luck there.
  • Fabwiz
Posted April 05, 2008 - 08:34 PM
I dont know if the 426 startor is the same but there is a guy on Ebay selling rewinds with light wiring for about $129
  • frankllynn
Posted April 05, 2008 - 08:36 PM
you have link or know the seller id.. Do you know the wattage? Thanks
  • Fabwiz
Posted April 05, 2008 - 08:58 PM
http://cgi.ebay.com/...sspagenameZWDVW
ee if this link will work, if not do a search on yz426f and you should be able to find it, acjracing is the guys user name on Ebay. Good luck
  • frankllynn
Posted April 05, 2008 - 09:29 PM
Has anyone rewound these there self? Is it hard to do?
  • Fabwiz
Posted April 05, 2008 - 09:33 PM
I have heard its a real pain to rewind stators. I talked to an electrical wiz we use for doing our starters and alts where I work, he said it a hard thing to do and get correct. I guess you have to know how much to wind on and then get everthing to fit back into the bike correctly. Don, the electrical wiz, said it takes a lot of labor time to do.
  • frankllynn
Posted April 05, 2008 - 09:41 PM
Thanks for the help. I may call baja designs for a rewind
  • Fabwiz
Posted April 05, 2008 - 09:43 PM
No problem
  • frankllynn
Posted April 06, 2008 - 05:37 AM
Anyone seen a kit for my bike with headlight wireing harness and stator. That would be nice.
  • fundgh
Posted April 07, 2008 - 11:49 AM
Doesn't a WR stator solve your problem? I have a plated YZ400f and it has a WR stator in it.
  • Fabwiz
Posted April 07, 2008 - 05:52 PM
I think you have to run the heavier WR flywheel with that stator though.
  • Qwik Gixxer
Posted April 07, 2008 - 08:54 PM
I have a Moose Stator on my 98YZ and it seems to be working great. Baja Designs may do a complete kit.
  • frankllynn
Posted April 08, 2008 - 03:14 AM
Someone told me a wr stator would not fit. Does anyone know what the wattage on the wr is. I was going to get a fww anyways. I would like to run a 55w bulb.
  • fundgh
Posted April 08, 2008 - 02:04 PM
I have a 99 YZ400F, and it has a WR flywheel/stator. I don't know the exact output, but I am running a headlight/taillight/blinkers/Horn. I didn't do the conversion, so I don't know what all was involved, but the previous owner swapped the two back and forth depending on what type of riding/racing he was doing. He claims that the WR setup gets significantly better gas mileage as well. I don't know what the stock YZ mileage was, but I seem to get close to 40 miles per gallon with the Street setup.
  • frankllynn
Posted April 08, 2008 - 05:50 PM
Could someone tell me how to wire it if I were to get the wr flywheel and stator.
I would also have to get a voltage regulator and I like the UFO lights. I guess I would also get an on off high low switch. Anyone have a diagram or know the wire color codes.
  • Fabwiz
Posted April 08, 2008 - 08:06 PM
Check out this site, maybe they have a manual that will show a wiring diagram for a WR http://www.yamaha-mo....ce/manuals.jsp
  • Hot  38 replies
  • Hot  50 replies
  • Hot  47 replies
  • 3 replies
  • On January 15, 2017
