We're re-jetting!
We will be performing site maintenance today (May 25th). You make experience a temporary slowdown during this time. Don't worry, we'll be back at full speed in no time.
KDX gear oil?
14 replies to this topic
  • Little Jeff
Posted April 04, 2008 - 06:41 PM
Hi there everyone, I am in the mist of rebuilding a 2000 Kawasaki KDX200. Doing a complete engine rebuild. I run Shell Rotella T 15-40 in my '02 KTM300EXC for gear oil and was wondering would that be OK in the KDX gearbox as well? I have no problems with it in my KTM, but that bike also has a Rekluse auto clutch and that's what Rekluse recomends for gear oil. Also, I heard that you should put more oil in the gear box of the KDX to stop some sort of engine noise. I read that somewhere on this forum. What oil do you guys run in your KDX and how much? Eventually this bike will be getting a auto clutch as well, but probably a EFM auto clutch, as Rekluse doesn't make one for this bike yet:rant:
Thanks in advance for your time and answers
Little Jeff
  • AwfulSmokey
Posted April 04, 2008 - 06:51 PM
Yes that will work and yes to adding more oil to quiet it down. Use 1 full quart.
  • SteveWR450F
Posted April 04, 2008 - 08:46 PM
I agree. Started using Rotella in my WR 450. It also had rekluse. Got rid of that big heavy bike and got 2 KDX 220s (one for me and one for the son). Been using Rotella in the KDX for 2 seasons. No problems. I go to Walmart and buy it in the 5 gallon buckets.
  • KDXGarage
Posted April 05, 2008 - 03:48 AM
My friend had a 1997 KDX220R. When he put in a full quart, it blew a fair amount out of the crankcase breather hose.
  • hi_im_sean
Posted April 05, 2008 - 05:52 AM
i use a full quart. manual says 700cc. or 7/10ths of a quart
the kawi manual says any 15w-40 motor or gear oil. ive used castrol 2t 15w-40 since ive had mine
  • KDXGarage
Posted April 05, 2008 - 06:14 AM
Sean, I think it is 10w-40 in the manual.
  • AwfulSmokey
Posted April 05, 2008 - 06:15 AM
It is 10-40 , thats what i use.
  • rdsrf
Posted April 05, 2008 - 04:07 PM
Do most people use a full quart of oil in thier KDX 200/220? I've always run the recomended 700cc's in mine and it does make a bit of mechanical noise. Any problems with it blowing out of the breather like stated earlier?
  • hi_im_sean
Posted April 05, 2008 - 04:26 PM
your right sorry. really early in the morning for me
  • AwfulSmokey
Posted April 05, 2008 - 05:17 PM
Not on mine. The previous owner has it routed into the airbox. I didn't mess with it.
  • camaro_guy_z28
Posted April 06, 2008 - 05:27 AM
I run the belray gear saver 80w. I can't remember how much i put in but i go by what the book calls for, no problems so far
  • trailnewcomr
Posted April 06, 2008 - 10:19 AM
i also run the bel-ray gearsaver but may have to switch (assuming walmarts rotella is cheaper)
  • piey62
Posted October 20, 2014 - 10:20 AM
Hi
Just got kdx 220 R bein going through it changed oil and filled it with 700c of 10 w 40 semi synthetic took it for mot today and back 14 Kms when I got back oil level on minimum where as it gone
  • OLHILLBILLY
Posted October 20, 2014 - 04:27 PM
I put around 850cc in mine, brings the level right to the top of the sight glass. I've been using ATF in it for several years now, use the same in the YZ, no problems with either..
  • OLHILLBILLY
Posted October 20, 2014 - 04:30 PM
Hi
700cc will put it at the bottom of the sight glass. If it's not smoking and spooging like crazy (leaking crank seal), put another 100-150cc in it and see how the level stays then.
