XRR oil level way low after oil change!
7 replies to this topic
  • mikesbaron
Posted April 04, 2008 - 04:16 PM
650R: Just changed the oil and filter on my XRR. Put in 1.7 liters, started her up for a few minutes, stopped her and let her set for a minute and checked oil with dip stick screwed all the way in and dip stick sitting on top of filler. Eitherway I'm getting only about 2mm of oil showing on my dipstick!:headscrat
The bike is on level ground too. What gives?
  • riding4life162
Posted April 04, 2008 - 05:09 PM
theres a sticky on the infamous oil capacity: http://www.thumperta...isplay.php?f=22
  • jetfuel
Posted April 04, 2008 - 05:14 PM
That sticky is for the"L" not the "R"....
  • mikesbaron
Posted April 04, 2008 - 07:57 PM
Ok, It's hard to tell, but here's what I come up with after looking at pics and reading the net.
(kudos to srcinc.net)
The XR has two oil pumps, mounted on the same shaft, driven directly off the end of the crank
with no reduction. The pumps volume will always be directly related to the cranks rpm, not the
gear you're in. The first one, we'll call it "A", is the one that you can see when you change the
filter. Behind it, is one with a larger volume. We'll call it pump "B". There is no direct flow
connection between the two.
Pump "A" gets it's oil from the bottom of the oil reservoir, via the downtube screen, and oil
filter. Pump "A" supplies the volume and pressure necessary to lube the engine and transmission.
It feeds galleries that go to the valve train, crank bearings and rod, transmission bearings, and
is splooged into the base via a jet for skirt and small end lubrication. The base (area around the
crank for this subject) is separated from the transmission. A one- way reed valve in the base
allows the used oil to be forced out with the pressure created by each downward piston stroke.
This eliminates "windage", which robs and engine of horsepower. Ever try running in deep water?
That's what oil does to the crank while it tries to spin around. This oil is fed back into a sump
to be reused.
Pump "B" is more than twice the thickness than "A". The reason for this is simple. Remember that
both pumps are on the same shaft. All of the oil that has exited the crank area, and dropped down
from the tranny, is collected into a sump at the lowest point in the cases, you can see the spot
from outside the bike . It's the point where frogs get wedged between the engine and skid plate,
and a few days later an odd smell, vaguely reminding you of KFC, begins emanating from the garage.
Any way, pump "B", with it's high volume, draws all this oil through the second screen in the
engine, a bigger flat one that can only be accessed by removing the RH crankcase cover (not the
clutch cover, but the big one behind it). The pump then fires the oil up the long metal tube up
the side of the frame, dumping it into the reservoir. Pretty simple huh? We've already followed
the oil through one use.
There is a second one way valve located in the cases, labeled as a check valve, located behind
the oil pump, that appears to allow oil to be blow into the sump if there is excess pressure.
Possibly it is there to prevent pump damage for us freaks in the north that have to start our
bikes in below zero temps.
Anyway, here's the short story. Oil looks to be gravity and suction fed from the reservoir,
through the downtube screen, the filter, and then into the "A" pump. "A" pump sends it to the
engines vitals. All the oil eventually finds it's way through the internals to the catch basin at
the engines lowest point, where it is sucked through another screen into "B" pump which dumps it
back to the starting point in the reservoir. Because "B" pump has a much higher volume than "A",
it cleans the sump of oil faster than it is supplied. This is what makes the BRP engine a "Dry
Sump" engine. Remember trying to run in the swimming pool? That oil that would slow the crank,
also will slow the transmission. It's all part of what makes this powerplant the beast that it is.
The two screens safe guard the pumps from ever getting something it can swallow, or debris from
clogging it's supply or exit. I have even found goldenrod in the downtube screen, which shows the
screen suits it's purpose. That also tell the guys who believe the crankcase vent doesn't have to
be filtered that they may want to rethink their ideas, but that's another thread.
The dry sump is the reason for checking the oil after the bike has been run. You've all seen the
newbies who don't read their manuals that have had to ask why they are pumping oil from the CS
seal and airbox. When the bike sits, all the oil eventually drains from the reservoir back into
the cases. It does so slowly, as the only exit is through the tight tolerances of the "A" pump.
These tolerances are less than .10mm at the smallest point. It gives you more than enough time to
shut down the bike and check the oil. No lightning speeds needed here.
Now that you understand how it works (I hope) I'll point out three things.
The First Point concerns the bleeding procedure brought up by Lloyd. This only my opinion, so
don't hold me to it. I'm anxious for when he gets the whole story from his service manager. As I
mentioned before, and you've all seen yourselves, the oil in the reservoir seeps down to the
engine when it is not running. The ONLY path is through the "A" pump and into the oil galleries.
This means that the most important pump in the system will always have oil, unless the bike is
file:///D|/XR650R/Tech%20Info/Lube%20system%20-%20how%20it%20works.txt (1 of 2) [7/27/2003 6:03:03 PM]
upside down. That's a point that is only relevant for you Edelbrock guys where the bike will run
in negative g environment. :-) OR, if the accumulated oil in the sump is lower than both of the
pumps. Is the oil capacity enough to make it to the required height?
I would have two questions at this point. If it was equal or higher, would not the oil make it to
the pump no matter what? All of the oil at some point would be only in the sump, as it can't
collect in the actual crank base. Remember the reed valve? I may be wrong here, as I have no way
of knowing how tight this valve is without suction behind it.
The second question, only valid if the accumulated oil in the sump was lower than the pump,
would actually be more of a point. If the pump was not being primed on it's own, pulling a bolt
would not make a difference. You'd be dumping oil from a passage before it was even getting to the
pump. There is no back pressure on the pump because of air, as the outlet from the pump has a free
shot (vent at this point) to the reservoir above, thus negating the need to bleed anything from a
bolt on the outlet side. If you just changed the oil, you know that "A" pump has juice getting to
it. Again, these are just my opinion, and the service managers explanation may change all.
There are three plugs that I see that would be relevant. They are all a shiny allen head cap bolt
located in the pump area. My opinion would be that they are more to block holes required in the
machining process than anything else. Though they may be handy to drain water from low points for
those of you who, like me, have discovered pigs don't float.
The second point was mentioned by Alan and Bruce earlier. You can't splice clear tubing into the
metal inlet tube, as the only time oil is present in the mentioned area is when the bike is
running, then it would be full and flowing into the reservoir. When the bike is shut down, the oil
will seep back down the tube, through the pump, and collect in the cases. It would never hit a
point of equilibrium with the level in the reservoir and show an accurate reading.
The third point is for Joss B (Congratulations if you've read this far!). You mentioned cracks and
dents between the crank and cases. If I were you, I'd take a Dremel with a abrasive bit and clean
the cracks. Just V them out a little and give the surrounding area a rough surface. Two reasons,
it makes a sticky surface, and the grinding kind of rolls the metal onto itself, helping plug
small cracks. Degrease the area with contact cleaner and then put a thin film of some sort of
sealant on them. I was going to suggest an epoxy, like JB Weld, but I wouldn't trust it on a
surface application like that. If it came free, those large chunks would wreak havoc before they
were caught, where a little silicone floating around would be a lot easier on the innards.
If they are just small cracks, it may be no worry, I'm sure the oil seeping in from the tranny
would be a lot lower volume than what was being forced out. Just the grinding alone may stop a
slow seepage. The next thing would be sure that the cracks are only cracks, and there is no
structural weakness there. Chunks of case would probably be hell on bearings and gears.
Thanks again to the group for giving me excuse to pass a few minutes (Actually more than an two
hours this time) and keep my sanity a little longer. This has got to be the longest, oil related
post, I have ever seen that didn't start with "What oil do I use?".
The Haymaker
As found http://www.xr650r.us/tech/lube.pdf
  • gottaski
Posted April 04, 2008 - 10:20 PM
OK. i have bad ADD.
anyone wanna put what he said into jsut a few lines?!? :prof:
  • scalejockey
Posted April 05, 2008 - 04:35 AM
OK. i have bad ADD.
anyone wanna put what he said into jsut a few lines?!? :bonk:
If you want a true reading go out and ride it for about 10 minutes.I have a sight tube on mine and it takes a while to see max fill level.:prof:
  • Ferdinand
Posted April 05, 2008 - 01:33 PM
If you want a true reading go out and ride it for about 10 minutes.I have a sight tube on mine and it takes a while to see max fill level.:thumbsup:
What he said.:thumbsup:
  • gottaski
Posted April 07, 2008 - 05:34 PM
thank you for translating that!! i do that anyway, so it's nice to know i am doing something right!!
  • Hot  35 replies
Honda XR650L 2016
  • 0 reviews
  • 17 replies
  • 22 replies
