wr 450 sprockets.
20 replies to this topic
  • Alaska
Posted April 04, 2008 - 01:42 PM
I am thinking of stepping down my rear sprocket for a bit more top end. Has anyone done this?
  • mattcanWR450F
Posted April 04, 2008 - 04:40 PM
no i have not, but i was thinkin about doin the same thing.
  • simica
Posted April 04, 2008 - 07:06 PM
With the wide ratio trans, not too many people go down on the rear sprocket unless you ride on pavement alot or open desert.
  • dirtysouth
Posted April 05, 2008 - 06:26 AM
Did it...went to 45 rear. Found that top end gain is not worth the bottom end losses for me...back to stock now
  • Mutu
Posted April 05, 2008 - 09:54 AM
14/48 for me. 14/50 stock. I tried 15/50 but the acceleration sucks....
14/48 is in between the two.
I think yamaha on the money with 14/50 gearing for stock.
  • ckroto
Posted April 05, 2008 - 12:29 PM
running a 14/49 since new. The stock would probably be ok, but I run more open desert.:thumbsup:
  • martin450
Posted April 05, 2008 - 01:23 PM
I'm using 14 38 at the mo , the longest 1st gear ever , i hate it but it does pull well on the open road above 70mph (i'm running supermoto wheels at the mo) , i'm going to 14 49 now though as the open road is not what a wr 450 is for, but it does work for the road if ya wanna cruise :/ but ya dont wanna cruise do ya ! :thumbsup:
  • justbackitin
Posted April 07, 2008 - 06:15 PM
I run 16-47 on my dual sported wr. Sure it's tall but I still has more than enough power to spin the rear wheel up in almost any condition. I sort of wish it was taller for highway cruising. Maby I'm crazy though.:thumbsup:
  • face_plant
Posted April 08, 2008 - 10:57 AM
14/41 street (tops out at 110 massive head shake)
13/54 dirt
street gearing sucks in the woods 1st gear is like 3-4 with the knobbies
  • taycam
Posted April 09, 2008 - 05:30 PM
I run 13/50 Dirt and 15/50 Dual sport....front sprocket is a quick change, done in 15 min
  • canyonclimb
Posted April 09, 2008 - 05:54 PM
Agree completely. 13/50 great on tight wooded trails, 15/50 for open dunes
  • JP WR450F
Posted April 10, 2008 - 05:41 AM
I'm running a 16 /46 it tall in tight area's but we do big trips up to 1200 miles :thumbsup: also did great things for my milage I get 45-50 going down the road
  • speedcomm
Posted April 20, 2008 - 01:10 AM
Are you guys changing from 13 front to 15 front sprockets changing chains as well, wouldnt think there would be enough adjustment in the chain adjusters.
  • tweav
Posted April 20, 2008 - 03:08 AM
don't forget that when changing sprockets , always buy try to buy odd number teeth sprockets they last longer . because both the inside and the outside links hit every tooth , instead of like a even number teeth one the same kind of link always hits the same tooth .and always use lock-tite.
  • JP WR450F
Posted April 21, 2008 - 06:46 AM
I was had enough adjustment for 3 teeth but it was close
  • taycam
Posted April 30, 2008 - 06:04 PM
plenty of room for chain adjustment, you just have to modify the case saver a bit to fit the 15.:eek:
  • mikeythefokker
Posted May 01, 2008 - 10:08 PM
I ran a 48 when I was running a yz wheel on the back of my 07 and I didn't like it much for climbing hills, or really for anything. It kind castrated the bike. Maybe the stock 50 is a bit deep, but when you want that instant thump, it is always there.
  • Rick1141
Posted May 02, 2008 - 04:07 AM
Which year model WRF are you talkig about?? Stock 2003-2006 is 14/50. Stock 2007-2008 is 13/50.
I am riding my 2008WR450F with 14/48 in Baja and 13/52 in the woods. It works well.
  • PBDBLUE
Posted May 02, 2008 - 05:25 AM
Depends on the motor. My desert bike with the motor mods (yz cam,etc) I like 14/48. Just a bit more top end and with the warmer motor spreads the gears out just a bit. When I ride in the mountains I swap the back to a 52.
  • bajarider08
Posted May 04, 2008 - 09:59 AM
I run 14/50 for desert terrain. Gained 5 MPH over stock, still loads of low end grunt.
