why so much clutch variation?
12 replies to this topic
  • gbalias
Posted April 04, 2008 - 11:48 AM
on my 2000 426, i did the whole 2001 clutch upgrade. i noticed that the range of temp and the effectiveness of the clutch changes a LOT now. on the original 2000 setup, i could ride all day and never have to adjust the clutch cable or anything.
heres what i noticed. the first race on my new clutch (im talking supermoto only on this bike) i assumed id need to make some adjustements, which i did and all weekend, the bike ran fine. a week later when i started up the bike and rode it, when i released the clutch lever, the clutch was still 'engaged' and it was slipping. when i re-adjusted the cable, it works fine now...but will it move a lot again this weekend? i have another race.
i didnt know if it was due to brand new clutch components and they needed breaking in, or if thats the way they are on the upgrade.
i really wont have time to adjust it on the course obviously. theres no triples i can jump and make changes in the air. :prof:
  • gbalias
Posted April 04, 2008 - 03:30 PM
no one experience this?
Posted April 04, 2008 - 03:42 PM
You shouldn't have a lot of change in the adjustment unless the clutch is slipping, it seems to me.
  • gbalias
Posted April 04, 2008 - 05:24 PM
it doesnt slip when its adjusted properly.
its just that it seems when it heats up (so it seems) the clutch has a hard time disengaging. so i have to adjust for it after that. then after it cools, or a few days later, when i ride it, when i let out the clutch lever, itll slip as if the cable is way too tight.
i was hoping it was normal for a new set of plates, but i dont know about this one.
  • gbalias
Posted April 04, 2008 - 08:17 PM
well, ive got a race sunday, so ill just bring my old clutch plates with. if i have major problems, ill just swap out the plates. i just dont think i can get it up to temp around my neighborhood as if i were on the track, so unfortunately...im flyin blind here.
Posted April 04, 2008 - 08:19 PM
The new plates were OEM parts?
  • gbalias
Posted April 05, 2008 - 01:59 AM
ebc if i recall correctly.
you thinking thats the problem?
  • William1
Posted April 05, 2008 - 03:24 AM
Most likely. Some plates swell more than others. To make clutch variations go away (at least not a problem) I install Magura clutch jacks. They compensate for and changes automatically. Plus no cable to clean or lube. One less thing.
Posted April 05, 2008 - 07:48 AM
Yes. The silicon content of the aluminum core of the friction plates in some after market replacement plates is too low, and this causes excessive expansion when heated.
  • groundpounder450
Posted April 05, 2008 - 07:59 AM
ebc is bunk?
Posted April 05, 2008 - 08:16 AM
There are very few aftermarket clutch kits I will trust, Hinson and GYT-R being pretty much the only ones. EBC is not on the list. The latest Barnett stuff is said to be good, but I stopped using them a long time back because I had problems with them. They may have changed since.
  • IDAHOBALLER
Posted April 05, 2008 - 08:56 AM
My clutch on my 08 will go spongy if I slip it a lot in real tight terrain, and has done it to me a couple of times on one particular ride that I was on. I have realized that the 450 doesnt like tight spaces anyways, it needs some room to breath and run like a 450 should.
I agree with Gray, in my experiences with all different types of 450 motors once they get pretty built up they are very hard on clutches and the only clutches I have found that are up to the challenge are the oem stuff. I have never tried any Hinson stuff because that stuff is sooo expensive. I did however try the barnett setup in my YFZ quad and i burnt that clutch up after about the 4th drag pass.
  • gbalias
Posted April 05, 2008 - 10:55 AM
my bike is all stock except a slip on and jetting.
i just went out and flogged it for a while. so far the adjustment i made a few days ago is holding up. ill ride it as is, and just take along my old plates if needed.
thanks a lot guys! :thumbsup:
ill let ya know how it does.
  • 0 replies
  • Hot  50 replies
  • Hot  113 replies
