Stator for 86XR600R
15 replies to this topic
  • mbjr1
Posted April 03, 2008 - 06:18 PM
I seem to have a very weak spark... So about how much will a stock stator for a 1986 XR600R set me back? Also what year and model bikes are compatible with mine, and where would be the best place to look if there are not any on Ebay?:prof:
P.S. looking for the cheap, not the performance stator (stock is fine for my purpose)
  • RipperFox
Posted April 03, 2008 - 07:16 PM
First off, BE SURE ITS THE STATOR. Get a multimeter and test the ground to coil resistance. Anything above 320 is toast. 0 would mean short..not good.
Second. Would you have the ability to rewind it your self...Its not that hard. Magnet wire,devcon and a little knowledge and bang...New stator.
A local starter, electric motor shop might rewind it for you. Those "mom and pop" shops have been slowly disappearing with the influx of cheap Far East motors and the like. But some may still be around.
If you even want to consider rewinding it your self, PM. I will get you some instructions and a line on the wire ($20) , and epoxy (Devcon, $10)
  • cleonard
Posted April 03, 2008 - 11:21 PM
The stators up to 90 are a direct fit. I think that the later ones will fit as well, but the wiring is different.
You can get a Ricky Stator for about $130, but I believe that the ignition winding is not new, only the lighting coil is new.
Forget Honda $300+.
I rewound my own. Not that hard, but tedious. Some instructions here. http://crustyquinns....ech/stator.html
Be sure to use high temperature epoxy.
You can always try ebay.
  • mbjr1
Posted April 04, 2008 - 12:28 AM
Hey thanks for the info guys, looks a little intimidating for the stator rewind. I;m looking on Ebay for one right now... no luck yet...
  • bajabinder
Posted April 04, 2008 - 06:59 AM
"You can get a Ricky Stator for about $130, but I believe that the ignition winding is not new, only the lighting coil is new"
I have a hard time believing this. I bought a R.S. stator for my old '87XR600R, BECAUSE of weak spark from the stator. I'm fairly positive it had NEW windings....
MBJR1, I would suggest that you buy a new stator (unless you rewind). Putting in used/ unknown parts is always a crapshoot. And, how much more $$ will it really cost compared to buying used? My '87 left me stranded too many times, too far from home, because of the stator.....Do ya feel lucky?
  • Motosprtman
Posted April 04, 2008 - 09:51 AM
search for Ricky stator on ebay and or go to thier website. 130.00 bucks brand new.
  • Motosprtman
Posted April 04, 2008 - 09:55 AM
New Complete High Output Stator Assembly
Fits:
XR600R 1991 on
Includes:
Charging/Lighting Coils. Lighting output of 200+ watts.
Source Coils
Harness and Plugs
This stator can be configured as either a single output of 200 watts or a dual output of 100 watts each. Single and dual output configuration instructions included.
A heavy duty AC regulator is highly recommended in place of the stock AC regulator for a single output configuration. If you want to use this stator for additional lighting with no battery in the system, the single output configuration is the preferred method.
http://cgi.ebay.com/...sspagenameZWDVW
  • 426_kid
Posted April 04, 2008 - 09:56 AM
If I remember correctly the 85 86 87 are the same?
  • Motosprtman
Posted April 04, 2008 - 10:07 AM
should be yes, tell em the year of your machine when ordering.
  • SniperTeamBravo
Posted April 04, 2008 - 10:26 AM
I have an extra one Ill sell ya for $40.00 plus 5.00 for shipping.
sniperx@netscape.com if interested.
  • mbjr1
Posted April 04, 2008 - 11:44 AM
Found this, it says it fits all the years and models listed below:
Moose Ignition Stator and Lighting with 2X100W Output
Dennis Kirk Part #: 201294
Manufacturer Part #: ESG410
* Moose Ignition Stator and Lighting with 2X100W Output
Your Price: $159.95* Part 201294 fits the following machines:
* 1982 Honda XL500R
* 1984 Honda XR350R
* 1985 Honda XR350R
* 1986 Honda XR600R
* 1987 Honda XR600R
* 1988 Honda XR600R
* 1989 Honda XR600R
* 1990 Honda XR600R
* 1991 Honda XR600R
* 1992 Honda XR600R
* 1993 Honda XR600R
* 1994 Honda XR600R
* 1995 Honda XR600R
* 1996 Honda XR600R
* 1997 Honda XR600R
* 1998 Honda XR600R
* 1999 Honda XR600R
* 2000 Honda XR600R
Seems there are alot of compatible years according to this...
http://www.denniskir...Id=3498#fitment
  • Ch47_pilot
Posted April 04, 2008 - 06:42 PM
You say you seem to; how do you know you have a very weak spark in the first place? What are the symptoms of your problem? Lets figure that out first before we all decide you have a bad stator. Unless you are just looking for a good excuse to throw some money at your bike.
  • RipperFox
Posted April 04, 2008 - 08:10 PM
Likes me says b 4....Multimeter connects to the coil bone...Much resistance...Bad...No resistance...bad...bikie no run...Resistance just right...Problem elsewhere.
  • mbjr1
Posted April 04, 2008 - 09:07 PM
So far we just grounded the plug on the head and cranked it, it had a weak yellow spark. We used my plug in his 92 XR600, did the same thing and it was a decent blue spark.
It was a crude test, but didn't have a multimeter on hand... I'm ruling out the plug wire for now cause it looks brand new, think it was recently replaced, plug was good also. Also checked the carbs thoroughly, jets are right size according to Eddie Sisneros (AKA burned), the floats seem to be working properly and the needle adjustments were right on.
Sorry if I didn't explain everything, I have other posts up Here (Problem): http://www.thumperta...ad.php?t=625971
And Here (Jetting Forum): http://www.thumperta...ad.php?t=626899
  • Ch47_pilot
Posted April 04, 2008 - 10:27 PM
Do a thorough compression and leakdown check first.
  • mbjr1
Posted April 04, 2008 - 11:02 PM
Yeah we will do the compression and leakdown check for sure.
