Water Pump Impeller
1 reply to this topic
  • Guy
Posted November 10, 2002 - 10:54 AM
I opened up the water pump on my 99 WR to change a leaky seal and found the impeller had sheared from it's nut to leave it free behind the nut ! :)
It's obviously still been turning as I haven't overheated and also by the marks......
Has anyone else had this prob, if so did you use Yam parts again of is there an aftermarket alternative ???
  • Richard56
Posted November 10, 2002 - 11:41 PM
I had that problem once... but after I changed it to the 2000 WR400F impeller shaft, It works excellent :) :D
