water in motor
19 replies to this topic
  • Sey
Posted November 10, 2002 - 07:13 AM
Went for a mud ride yesterday ,no problem. Gave the bike a "good washing" wouldnt start after. still no start this morning. pulled the sparkplug, kicked it over, WATER coming out! Any tips on what to do next?
Seym
  • Rich_in_Orlando
Posted November 10, 2002 - 09:21 AM
Been there, done that.
With the plug out, kick it through until no more water shoots out. Stand the bike up on end to pour out any water that may be in the exhaust. Clean the airbox and boot. Put in a clean and oiled air filter. You may also have debris in the carb float bowl and jets, so check and clean that.
Drain the oil, take out the oil filter and screen and clean them. Replace the oil with some cheap motor oil and put everything back together.
Get a new plug and start it. If it won't start by kicking, try pull starting it. Run it for a few minutes, then drain the oil again, check/clean the filter, and replace it again with cheap oil. The drained oil should look pretty clean by now. If it does, run it for a few minutes, drain the oil and replace it with whatever normal oil you use. If it doesn't, keep repeating the oil replacement until the oil comes out clean, then finally replace with good oil. Then you're back in business.
  • bigdrtrdr
Posted November 10, 2002 - 09:22 AM
change the oil 2 or three 3 times or until it comes out not looking milkey Ive swamped mine out in a creek before and did the same thing. Also when you are spraying it off dont spray into the right side hand hold,it can fill up the airbox which will drain into the carb and cylinder if the air filter isnt waterproof.
Good luck
Eric
  • crf250riderz
Posted August 04, 2009 - 08:26 PM
hey my motor oil is dirty from swamping my bike i've changed my oil 5 times and it still comes out dirty. not sure what to do just keep flushing it or what? it is a crf250r by the way
  • crf250r_motorhead
Posted August 04, 2009 - 08:28 PM
pretty much. no way to get around it....
  • crf250riderz
Posted August 04, 2009 - 08:29 PM
what do you mean by that? is the motor done?
  • crf250riderz
Posted August 04, 2009 - 08:30 PM
it runs like a top lots of power just has dirty oil
  • crf250r_motorhead
Posted August 04, 2009 - 08:31 PM
is it water dirty or just black dirty?
it doesnt take long for oil to get dirty. but if its milky you have water or antifreeze in your motor.
  • crf250riderz
Posted August 04, 2009 - 08:32 PM
it is black dirty
  • crf250r_motorhead
it is black dirty
wouldnt worry about it then.
how often do you change it?
  • crf250riderz
Posted August 04, 2009 - 08:34 PM
this is what i have done so far. took the plug out kicked it over until water quit coming out. need new plug. changed oil five times haven't rode it much lately because of the oil i don't wanna run it with black lookin oil. it starts normal runs normal a little worried i don't know much about 4 strokes
  • crf250riderz
Posted August 04, 2009 - 08:35 PM
i change it at the most every 5 hours and maintain it very well
  • crf250r_motorhead
Posted August 04, 2009 - 08:36 PM
as long as its not milky or appearing to have any foreign substance in it i would say your better than good on a maitenence schedule like that!
my oil is dirty as sin when i change it. i change it every 2-3 tanks of gas maybe,and thats pushin it. your good bro!
  • crf250riderz
Posted August 04, 2009 - 08:40 PM
haha ya i'd rather pay for maintenance then another $1200 rebuild. thanks for the advice man i'll let you know how it goes. and how many times i end up flushing it
  • crf250r_motorhead
Posted August 04, 2009 - 08:41 PM
welcome :thumbsup:
better to play it cautios than to have a grenade go off in your cylinder! haha.
  • crf250riderz
Posted August 04, 2009 - 08:45 PM
o ya sorry to bug ya but have you heard anything about these bikes cranks going. i bought my 07 second hand with 40 hours on it and i rode it about 20 hours and the crank went. should i change crank or piston at a certain time so they don't cause more damage in the motor if they go or should it be good. how long does the piston last also?
  • crf250r_motorhead
Posted August 04, 2009 - 08:50 PM
piston at about 40 hours and a crank at 80-100 hours.
but everything is different. you could have got a dud of a bearing from the factory..
or the guy who had it before you slacked like hell on keeping the bike up. another reason ill never buy a four stroke. you should be good now though as long as you keep fresh oil in it.
  • pepsi0530
Posted August 04, 2009 - 11:18 PM
Cheap Oil? Can I use regular say 10/40 car oil to flush then normal 4 stroke motorcycle oil will that be good enough.
  • crf250r_motorhead
Posted August 04, 2009 - 11:19 PM
itll be a-ok.
thats what i did when i fell through the ice :thumbsup:
  • Woodrider37
Posted August 05, 2009 - 01:59 PM
My 2007 WR250f had been under water more than 6 hours. I tried repeat with motor oil to removed water in the engine. Find that air compressor did real good work to remove water. Unplugs all you can then blow the water out at other side. Wear safety goggles before do it.
