Very stupid question, but what way do you tighten spokes?
22 replies to this topic
  • William1
Posted April 04, 2008 - 05:37 AM
#21
I too, use the 'ping' method on old wheels. There is too much stiction in the spoke nipples on an old used wheel to have a spoke torque wrench be accurate. However, when I build a wheel myself, I use anti-seize on the spoke threads. I use the spoke torque wrench. It does do a better job than by ear. To do this on an old wheel, you would need to remove the spokes, chase them with a tap and die, anti-seize. Ugh, I need a nap!
Posted April 04, 2008 - 06:25 AM
#22
I use paraffin (from any grocery store, with the Mason jars). It's preferable to anti-sieze because there is no oil base to sneak into the wheel and attack the rim strip/tube/tire, and because it's a bit more temporary.
I will use a spoke torque wrench to get the spokes in the right range of tension, but even on a new wheel, I use tone to balance the tension. IMO, it's a more accurate indication of the actual tension on the spokes.
  • William1
Posted April 04, 2008 - 08:04 AM
#23
Gray, the paraffin idea is a good one. Also will 'seal' the spoke threads a little. Next wheel, I'll give that a go.
  • Hot  36 replies
  • Hot  50 replies
