Please Help!
4 replies to this topic
  • spy
Posted May 01, 2002 - 08:20 AM
Have been stressed with jetting issues on my '98 WR400.
My current jetting settings as follows:
170 Main jet
48 Pilot jet
DVR Needle clip #1
Have no problems in acceleration except for a 'flat spot' at 1/3 - 1/2 throttle position.
Thought this throttle position was affected by the needle position so tried to richen it by 1 step down on clip #2.
First test seems more responsive, 'flat spot' felt better(abit).
Tested it again next morning, seems that moving the clip to #2 took out my top end. It hesitates and will not accelerate at 3/4 - full throttle.(too rich?).
Oh i am using a fmf header(which one i dont know) and a WR stock silencer. Thats about it.
All views welcomed.Thanks in advance. :)
[ May 01, 2002: Message edited by: spy ]
  • YAMAKAZE
Posted May 01, 2002 - 03:11 PM
Check my settings with the FMF Powerbomb Header. Your bike is stumbling because it's too lean coming off the pilot. You will need to change the Pilot jet to a 48 and the Pilot Air Jet from the stock 75 to a 100. If you can get your hands on a EKN Needle that will provide an explosive low and mid range as well.
Bonzai :)
  • spy
Posted May 01, 2002 - 08:43 PM
What about my 3/4-full throttle problem?
I know we dont use much of this off road but i need the top end to travel to a neighbouring country just for trails or tracks.
At clip #1 my top end is Ok. I move it down 1 step and it doesnt accelerate, just gasping for air.
Thks
  • spy
Posted May 02, 2002 - 08:45 AM
Post deleted by spy
  • Taffy
Posted May 02, 2002 - 09:23 PM
try a 160-162 MJ
try lifting the needle to clip 4. do the MJ first and the needle second.
the needle is poor, very poor. DRM or EMM would be better.
i can't agree with yamakaze's pilot settings. my settings were all for the euro pipe which is what i run.
check my sigiture at the bottom of this post.
Taffy
